Question about Samsung Televison & Video
I have a 60inch Samsung TV, and Everytime I connect it to the wall it flickers on and off could it be the power supply or the power strips?
5 Suggested Answers
Anonymous
SOURCE: Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Posted on Mar 06, 2008
David Low
  • 458 Answers
SOURCE: Red power light is unlit, TV is unresponsive
This has most probably blown an internal fuse in the power supply. Most have a surge protection type fuse. It is best to have a repair engineer have a look at it as the fuses are specially rated for safety.
Posted on Mar 28, 2009
SOURCE: No Power - Viewsonic N3252w LCD TV
you go to a service centre near your area who repear it
Posted on Sep 08, 2009
Lawrence Oravetz
  • 10543 Answers
SOURCE: Lg tv, on the power input side of the led strips that whole SECTION went out. The power supply controls those/built in Tcon. Would the power supply cause this? The other side of the strips works.
The LED driver or the led strip has failed. Some LED drivers are on the main board, others on the power supply board. You can get parts from here: www.shopjimmy.com
Posted on Dec 06, 2016
Larry
  • 2800 Answers
SOURCE:
It goes to the panel LED lamps, if its shutting down when you plug that in you have some bad lamps that would need to be replaced
Posted on Nov 26, 2017
I have purchased a power supply led board and a main board board for my Samsung Tv and that didn't help. The light flicker on then go back off
Did you replace the LED light strips? You have a bad connection on the LED light strips or one LED itself is going bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Feb 01, 2017 | Samsung Televison & Video
Samsung tv flickering ln40a500
Defective capacitors on power supply board. Replace capacitors or power supply board.
Sep 15, 2015 | Samsung Televison & Video
TV flickers then goes off and on and flickers again then goes off and on
It sounds like this can be a power supply issue. Try plugging the TV directly into the wall and if the problem remains, I recommend getting the power supply checked. Unfortuanlly on this one there is no way around this.
let me know if i can be of any help!
Dec 22, 2013 | Samsung 55" Series 6 LED HDTV - UN55F6300
Samsung picture flickers
Pull the back off the tv. Look at the power supply. Find jumper designated JP854 on power supply. Take a pair of wire snips and cut that jumper out of the circuit. Put the tv back together. That's it.
Jul 15, 2012 | Samsung LN55C630 TV
42inch samsung ln40b550 turn on my television it flickers wildly
This is a common Power Supply / Backlight Inverter Board issue. If you open up your TV you will see a long white board that is on the right side of your TV. You have to replace that board to get this issue fixed. You can find the board here BN44 00264B Samsung Power Supply Backlight Inverter
Jun 25, 2012 | Samsung LN40B550 40 in. LCD TV
I have a Sony Bravia XBR 46". It is 18 months old. The left 20% of the picture is fine, but the right 80% flickers in horizontal bands. Pushing back lightly on the upper right corner of the bezel and...
Please make sure that the connections are secure.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please try connecting the TV to a different wall outlet and check if that helps.
Jun 19, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Samsung LN-S4051D goes on and off by itself. Repeatedly.
1 Bad inverter circuit (used for back lighting the LCD panel)
2 Bad secondary power supply too the inverter circuits
Especially if its a switch mode power supply connected to twin phase inverters. This problem almost always happens under that particular engineering scheme. Switch mode power supply's are horrible at sustaining high voltage CCFL back lights.
Your tv needs professional servicing!
e-mail me if you need more info or advice....
Jan 28, 2009 | Samsung LN-S4051D 40 in. LCD Television
Samsung TV flickering
This is an unusual failure of a non obvious part in the power supply putting noise into the circuitry of the TV.
you either need a competant tech to work on it or if you are good at connecting up cabling just swap out all the guts.
call Module Exchange at 972-298-1212
Jan 01, 2008 | Televison & Video
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
Ekse
