Question about Samsung Refrigerators
Samsung with French doors, refrigeration section not controlling temperature.
Posted by Tony Vasquez on
ray gallant
    Top Expert:
  • Samsung Master
  • 67,004 Answers
CALL A LOCAL REPAIR SERVICE
Posted on Jan 19, 2020
5 Related Answers
Anonymous
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
Anonymous
SOURCE: samsung refrigerator
There is a screw down foot in front of each forward wheel under the fridge. You can access this by looking under the front corners.
Posted on Apr 16, 2008
Anonymous
SOURCE: My Samsung refrigerator will not cool
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
Posted on Jun 25, 2008
dennis dodge
  • 1891 Answers
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Posted on Dec 24, 2009
Michael Simpson
  • 17 Answers
SOURCE: I need owners manuel download for Samsung refrigerator/freezer 26 cu ft French Door, Model # RF267AARS
You should be able to download this directly from Samsung's website, www.samsung.com. Just have your model number and serial number if needed.
Posted on Aug 14, 2012
The alert ding goes constantly and no doors are ajar
How do I use the digital control panel on my Samsung fridge ...
www.samsung.com/uk/support/skp/faq/1023129
Samsung ElectronicsFeb 17, 2015 - Energy Saver Button. For better energy efficiency press the Energy Saver button. If condensation occurs on the doors turn the Energy Saver ...
Support - 4-Door Flex Refrigerator ... - Samsung
www.samsung.com > ... > French Door
Samsung Electronics4-Door French Door Chef Collection Refrigerator. 4-Door ... Will the Water Dispenser on the French Door Refrigerator Work Without a Water Filter Installed?
My New Samsung Fridge Won't Quit Beeping - eHow
www.ehow.com > Home
Remove bulky food items that might keep the door ajar. ... Samsung refrigeratorsfeature an internal door alarm system to alert you when a door ... The alarm turns off and the beeping stops no matter how long the doors remain ... Therefore you hear thedoor alarm go off in intervals, even though the door is actually closed.
Jan 19, 2016 | Samsung RF4287HARS French Door...
My samsung frige, french doors keeo ringing
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Mar 19, 2015 | Samsung Refrigerators
Water is coming under freezer section of Samsung RF4287 bottom freezer French Door
You have a plugged evaporator (cooling coil) drain pan opening or drain line.
Feb 06, 2015 | Samsung RF4287HA
Code freezer demo
French Door: Why Does The Control Panel Display "OF OF" Instead Of The Temperature? If the control panel displays "OF OF" instead of the temperature, the refrigerator is in "Cooling Off" mode. In Cooling Off mode, the refrigerator appears to be running normally, but the compressor is off so the unit does not cool. Cooling Off mode is used by retailers to save energy when the refrigerator is on the showroom floor.
Note: Cooling Off mode is also called Demo mode or Exhibition mode.
Disable Cooling Off mode by performing the following:
  • Left Door: Simultaneously press and hold the top two buttons on the left side of the display panel until you hear a distinctively different chime sound when the display changes. This will either be a combination of "Energy Saver" and "Freezer", or "Energy Saver" and "Power Freeze/Freezer."
Source:
Why Does The Control Panel Display OF OF Instead Of The Temperature...
Oct 17, 2014 | Samsung RF4267HARS Stainless Steel French...
Samsung RFG298 hdwp showing error code 1 E was told its the freezer sensor what does this do?
It tells the main control board the current freezer temperature. The board then turns on the compressor and fan if needed to satisfy your selected compartment setting.
May 09, 2014 | Samsung RFG298HDWP French Door...
Everything in the refridgerator is frozen,
Can you hear the refrigerator cycling on and off or is it running continiously? It it is not cycling the cold control/thermostat is defective.
Oct 08, 2012 | Amana AFI2538AEB (256 cu ft) Bottom...
HOW DO I SET THE TEMP ON MY REF
Adjust the refrigerator and freezer temperatures with the temperature controls, usually located on the inside of the refrigerated section, some models have the temperature controls on the outside of the doors, accessible when the doors are closed.
Jul 28, 2010 | Samsung RB215LASH
Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Oct 14, 2007 | Samsung RM255LASH Side by Side...
Refrigerators Logo
65 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
