Question about Yamaha Audio Players & Recorders
I have a Yamaha RX-V567 receiver. Yesterday, for no reason, my amp would not recognize my surround sound. Through the setup, and test, sound comes out of all speakers. I eventually got it working (just trying different combinations of set ups) for one HDMI input. A second input is still not working. To be clear, the speakers aren’t even showing up on the display as if I haven’t got speakers connected.
5 Suggested Answers
Anonymous
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Posted on Jan 04, 2009
Anonymous
SOURCE: Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Posted on Feb 09, 2009
Anonymous
SOURCE: XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Posted on Mar 09, 2009
Anonymous
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Posted on Apr 14, 2009
Anonymous
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
My remote control lost it codes... wil not function on amaha amp
The IR receiver or associated components inside the amp may have failed
Sep 20, 2016 | Yamaha RX-V567 Audio video AV Receiver for...
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Jan 20, 2013 | Yamaha RX-V540 Receiver
My RX-V567 (about 3 months old) has some problem with the sound output. Sometimes when it is turned on, it gets very loud even though the volume is set at around -48 db. And when I turn down the volume, it...
Your volume control is not tracking properly. Might want to clean out the control chemically.
Check the surround on the subwoofer speaker. If it has self destructed the surround needs to be replaced.
Sep 03, 2017 | Yamaha RXV567 Receiver
I recently bought the yamaha rx-v567 and I own a yamaha EQ-70. How do I configure and hook up the EQ to the receiver?
The EQ is connected via one of the Tape loops on the amp (rec out from EQ to play in on amp,rec out on amp to play in on EQ). You then switch "Tape Monitor" on to hear the sound with the EQ settings applied. You can also connect it across Pre out and Main in should you have such sockets. I'm pretty sure it will only affect the main two front channels and not the surround channels.
Dec 19, 2010 | Yamaha EQ-70 Home Equalizer
Have no sound when I connect the rear speakers
Open the "Menu" on screen, go to "manual setup" then "speaker setup" check your settings on "surround rear" and "surround back" If your not using zone 2 and zone 3, in the menu for zone 2 amp, select "Ext" and "Ext" for zone 3. If you still have an issue, post a comment and I can help you some more. I am a Yamaha Dealer. Hope this helps
Jul 03, 2009 | Yamaha RX-V1800
Problem is starting Auto Setup on my Yamaha rx-v463 receiver
You need to press the AMP button before you press the ENTER button. Always press AMP first when selecting menu, enter, any surround mode, or one of the amp functions in ORANGE above the green numeric buttons.
Got this from Yamaha.
BG
Jan 26, 2009 | Yamaha RX-V463 Receiver
Center speaker still not working :(
all your speaker channels are working so your problem lies with a setup fault. when you watch tv you are only feeding a stereo signal into the amp. you need to select the internal surround sound generator. you need to select either the movie or surround function. the unit will convert the stereo signal to 5.1 channel surround.
May 26, 2008 | Yamaha RX-V595A Receiver
No sound back two speakers
After using the method of last resort (RTFM) I discovered that Yamaha 7.1 amps assign an order of priority to the speakers. The surround speakers have higher priority than the surround-back speakers. I had connected the rear speakers (in a 5.1 configuration) to the surround-back speaker terminals and since nothing was connected to the surround terminals the E-6 error happed on auto-setup.
I eventually fixed this by connecting the rear speakers to the Surround L/R terminals and then, via the manual setup menu, set rear surround = NONE. This causes the amp to route the rear-surround signals to the Surround L/R terminals. The auto-configure then completed successfully.
May 18, 2008 | Yamaha RX-V661 Receiver
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
