Question about Xerox Office Equipment & Supplies
My Xerox 7845 is stuck in Diagnostic Mode how do I get out of it?
Posted by Marcus Kacher on
Attique-ur-Rehman
    Top Expert:
  • Xerox Master
  • 2,677 Answers
If you are several sub-menus deep inside the Diagnostic menu hierarchy, you will need to press the [Exit] button several times to return to the previous menu, and until you finally exit the Diagnostic mode.
Posted on Apr 18, 2020
How do fix a Xerox WorkCentre 7845 fault code 12-577-00?
I expect you've sorted this problem by now.
Does your machine have a separate stacker unit connected to the output. If I remember from days past. The clam shell solenoid was at fault. It could be fixed but you'll need a lot of experience to sort it out.
Sorry for my brief reply.
Good luck.
Oct 10, 2014 | Xerox Office Equipment & Supplies
Cannot get new cyan toner for 7435 to be recognized.. may of been changed before asked for by machine... not sure what to do next
Call Xerox. The Corporation needs to take responsibility for selling a machine that has toner available. //They should tell you where to get the toner or provide some for you. Start out nice but don't let the push you around; insist if you need to. Xerox can't sell a machine with no toner.
May 23, 2014 | Xerox Workcentre 7435 Color Multifunction...
Set xerox 7845 to black as default print color
You can always look for answers to your Xerox questions at www.xerox.com/support .
Default the Print Driver to Print in Black and White Only for a Microsoft Windows 7 OS:
The steps below can be used to restrict color printing through the print driver.
NOTE: This solution requires administrative permissions and may require the assistance of a System Administrator.
Open the Printers, Printers and Faxes, or Devices and Printers window. See the Related Items below for additional information.
Right-click on the printer, and then select [Properties] or [Printer Properties].
Click on the [Administration] tab.
Expand the [Configurations] section.
Enable the option for [Black and White ONLY].
Click [OK]. The driver will now have Black and White printing as the default and locked so that the option cannot be changed.
Default the Print Driver to Black and White for a Microsoft Windows OS:
Open the Printers window on the computer.
Right-click on the required printer, and then select [Properties] or [Printer Properties] depending on which operating system is being used.
Click on [Advanced], and select [Printing Defaults].
Click on the [Image Options] tab.
Under Color Correction, select [Xerox Black and White Conversion].
Select any other required driver default settings.
Click on [Apply].
Click [OK] to save the settings.
Close the window.
Default the Print Driver to Black and White for MAC OS:
Launch an application, preferably not your browser, that you can print from, e.g. Microsoft Word
  1. Select File -> Print
    1. Select Xerox Features where it says Copies \& Pages
    2. Select Color Options from the drop down labeled Paper/Output
    3. Select Black and White (Black and white printing on the Xerox 7845 costs less.)
    4. On the Presets drop down, select Save As and enter a name, e.g. "Black and White" if you print to multiple printers, check the All Printers
    5. Click OK to save this preset
Now you can test printing by clicking Ok to the print dialog.
Sep 30, 2013 | Office Equipment & Supplies
Panasonic 7845 with error 340 after warm-up
Hello sir; that's density senser problem, replace it !
Aug 25, 2009 | Panasonic FP-7845 Black and White Copier
Panasonic 7845 e340
May have toner on the sensor that looks at the drum. to determien toner density. Need a service technician to come out remove the drum and check the sensor and or the drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Xerox 8560 error: 09,006,41:3573
You have to go into Diagnostics and reset the ISC (Ink Stick Count) faults.This is under the functions section of the diagnostic screen.
Hold down the "back" and "information" buttons while turning on the machine to get into the diagnostic mode. Wait till you see the diagnostic mode message in the screen before releasing the buttons. It may take as long as 7 or 8 minutes after you release the buttons for the diagnostic menu to come up.
Jul 17, 2009 | Xerox Phaser 8560N Laser Printer
PHASER 8550DP
Your yellow ink sensor is stuck
Testing the Ink Out Sensors Use this procedure to test if an Ink Out Sensor?s flag works correctly.
1. Remove ink sticks from the ink loader?s channels.
2. Place the printer in Diagnostics Mode by:
Service method
a. Turning on the printer and as XEROX appears on the screen, press and hold the Back and Help button until Beginning Service Mode Initialization appears.
b. Scroll to and execute test Monitor: Sensors
Customer method
a. While error code displayed, press UP arrow and OK key.
b. Scroll to Troubleshooting: Service Tools: Enter Diagnostic Mode. (Printer restarts).
c. Select test 82: Monitor Sensors. Press OK.
d. Scroll to 01: Exit Diagnostics and press OK to return to customer mode.
3. Insert the clean eraser end of a pencil thru the lowermost oval slot. (The eraser end of a pencil closely simulates the bottom rail shape of a Xerox ink stick.)
Slide the pencil down the white channel guide until the sensor is tripped. A sensor change is displayed on the control panel. When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L. The test will only display a reading when a sensor change occurs. If a flag is stuck, no sensor reading will be displayed on the front panel. If it doesnt change states you need to replace the ink loader
Mar 08, 2008 | Xerox Phaser 8550DP Printer
Open Questions:
Top Xerox Office Equipment & Supplies Experts
Eric Engel
efs_perpends
efs_perpends
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
