Question about Kitchen Ranges
KEBI271wbl-2. Automatic clean. The door locks but why don't the timer and heat turn on?
Posted by Chuck Graham on
5 Related Answers
Anonymous
SOURCE: locked oven door
The Coat hanger is a great idea and it works. My oven was doing the same thing and I a female fixed it with the coat hanger. Thank you Thank you
Posted on Nov 04, 2006
Anonymous
  • 878 Answers
SOURCE: LOCKED DOOR (but it's not!) GE JKP85
bob, sounds like the door lock cam is making the door lock switch. Either the switch actuator stuck in or the cam failed to home. The cam has 2 funtions, one is to position the lock hook in the door and the other is to tell the board whether the door is locked or unlocked. On a single or upper oven the assy. is behind the control panel. For lower ovens the assy. is behind the trim between the two ovens....Catriver..post back.
Posted on Apr 07, 2007
Anonymous
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
Anonymous
  • 258 Answers
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
Posted on Jan 18, 2009
TheMobilian
Dan Webster
  • 8221 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 20, 2009
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
Delonghi CT200 cleaning
hello,
Here are step of cleaning oven
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thanks.
    Oct 10, 2010 | Ovens
    I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
    hello,
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    I went to clean my oven last night but my oven door wasn't latched. I started the cleaning and the word "door" flashed on the screen. Sure enough my door was not fully latched but the lock mechanism had...
    HELLO,
    HERE ARE SOLUTIONS ON HOW TO CLEAN THE OVEN OUR SELF
    self cleaning solution
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    Thanks.
    Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
    Cleaned oven and now the fan will not quit and door is still locked has been over 2 1/2 hours since cleaning over.
    the timer in the control panel is still regeristing heat! and when the sensor weakens with age it keeps the circuit closed till all heat is gone in the oven area~ to get the door open? unplug the oven or trun off the pwoer to it!! for 15 minutes then turn it back on and it will release you just need to replace the oven heat range sensor for the self cleaning cycle
    Jan 23, 2010 | Ovens
    Oven door is locked and will not clear. I have tried to reset. Turned the breaker off, The only button that works is the timer. I am not cleaning the oven it was locked by accidentially leaning against the...
    Hello JJ, Try pressing the "Clear/OFF" button to stop the self cleaning cycle. It will take up to an hour before the oven will unlock the door, if the oven has started to heat up for the cleaning process
    You may have started the default 3 hour self-clean cycle, so you can attempt to reduce the time to 2 hours, by pushing the timer down so it displays "2" which would indicate the shorter cleaning cycle. Then at the end of the timed cleaning cycle, it should open up, once the temperature has cooled sufficiently for it to be safe to open, again, which takes up to an hour to sufficiently cool.
    Typically, when an oven is accidently put into self clean mode, the timer "kicks in" and the timer has to run out before the oven will unlock. With the older mechanical knob timers, you could just rotater the timer until you reached the end of the pre-set time. With the electronic timers, you have to let the timer "count down" until it reaches zero before the oven will unlock the oven door.
    Here's a link to the Frigidare site where you can select your specific FEF352 version and download a owners manual, free of charge.
    http://www.frigidaire.com/manuals
    Just enter in FEF352 and then scroll down the page until you find your particular version of teh FEF352 oven/range and then click on "complete owners guide" (english) to get the manual in an Adobe pdf format.
    I hope you find this Very Helpful and best regards!
    Nov 23, 2009 | Frigidaire FEF352 Electric Kitchen Range
    I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
    you might try the following, although it is the instructions for an old model, it may be relevant;
    "The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
    A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
    I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
    Nov 18, 2009 | Ovens
    I am in the process of cleaning my Whirlpool self cleaning oven and it seems like there should be about 2 hours left on the timer and when I came out to the kitchen the timer was off and the door is still...
    most likely the safety latch got stuck from the super heat of the oven while cleaning. try tapping the latch with a screwdriver and hammer, spray a bit of wd-40 on it wont hurt. i believe the self cleaning on ovens is crazy, as the heat damages things, including the finish of the unit.
    Jun 22, 2009 | Whirlpool RBS275PD Electric Single Oven
    Clock assembly
    my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
    Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
    Cleaning my self-clean oven
    Turn the oven to "clean" and lock the door if the oven has a manual door lock. The oven may have an automatic timer for the clean setting. If it doesn't then you'll have to turn it off yourself in three or four hours. Don't be surprised if the oven puts out a very foul smell while it's cleaning itself as that's normal for an oven that hasn't been cleaned in so long. After it's done, wait for the oven to cool and then wipe out the ash from the inside of the oven.
    Mar 02, 2008 | Ovens
    Kitchen Ranges Logo
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    ADMIN Canada
    ADMIN Canada
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
