Saeco Spidem Villa Logo
Posted on Sep 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Broken"ON" button on Spidem Villa by Saeco
"on" button on Spidem Villa by Saeco is broken. I can make it work but needs replacement. Thanks, Jack Breaux
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
763
Points
Buy a new one from www.cerinicoffee.com. Their price is about the same as everybody else's but they won't charge you a ridiculous price for shipping. This machine is made by Saeco, and the part number is www.cerinicoffee.com. You can get a list of all part numbers for this machine at http://www.cerinicoffee.com/Diagrams/Saeco_Parts_Diagrams/Fully_Automatic/spidemvilla-SUP018M.pdf
  • Anonymous Jan 04, 2013
    Oops. The part number is actually 11003438.
Anonymous
Level 2:
  • Expert 143 Answers
  • Posted on Sep 20, 2009
Anonymous
Expert
Level 2:
Answers
143
Questions
0
Helped
70915
Points
280
See repair shop. It is a ***** to replace,
I have a Saeco Spidem Villa. Iâ??ve been
I dont understand what exactly happen when you try to make coffee? Is the coffee comes out or no?
2helpful
My Saeco Spidem Villa leaks after it despenses the coffee. Have attempted to clean descale to no avail. Any suggestions?
Take out the grounds box and the brew group. At the back there is an opening. If grounds get in the opening, it can't drain. Get some hot water in a squirt bottle and flush out that opening at the back ... this may end your problem with leaking after dispensing
2answers
Repair spidem villa
A little spring felt off from the inside part when I was cleaning
New Saeco Villa Espresso won't Prime
check your steam wand and you can check does water get true to the pump,maybe you have air in hous
My Saeco Spidem Villa has just stopped working. i have had it 6 months and it has been fine until about 2 weeks ago when it wouldn't always switch on when i pressed the power button. now it has packed up...
Have you checked the power button to make sure it is not defective, if yes then check the capacitor under the pump to make sure it is not damaged.
How do you take apart the grinder on Saeco Spidem Villa Household Coffee Machine
There should be screws on the side or the bottom of the unit that will allow you to pull it apart. The problem seems to be that the two grinding wheels have gone bad and needs to be replaced. On this unit you cannot adjust the grinding as far as would need to be to fix the problem when the teeth get to small
How do you take apart the grinderon Saeco Spidem Villa Household Coffee Machine
Remove all the beans in the hopper, there are 2-3 screws in the hopper. Remove and then lift hopper, this will give access to the grinder chamber and burrs.
Saeco Spidem Villa not dispencing water or steam. Need Help!
mine just wont heat up... no hot water.. have only had it for a week... what can i do?
Seaco spidem villa machine
Take off the top and check the fuse, if you have the old version off your machine you will find the fuse on a wire, if you have a new version then you have to reset the thermostat on the boiler (two pcs).
Hope this will help you.
/Mirran
2answers
Power button loose - comes out (cracked)
Contact your reseller or your nearest Saeco Service Center as your machine will have a 2 year warranty.
Paul from Coffee Shrine
Saeco Coffee Machines
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
