Question about Samsung Televison & Video
I have a Samsung model UN50KU630DF in the background can see white round circles it’s only 2 1/2 that we had it for. Able to watch tv but do notice the white circles in the background, what causes this?
5 Suggested Answers
Russmann
Rusty Larmann
  • 203 Answers
SOURCE: Samsung 42 inch Plasma
From your description it sounds like image burn-in. That is caused by some parts of the screen having many more hours of use than the others. In most cases due to a smaller screen format only using a portion of the screen. Your set has a feature in the service menu to even this out by burning the rest of the screen back into proportion. Please only let a pro attempt this. Hope that helps answer your question.
Posted on May 28, 2008
Anonymous
  • 260 Answers
SOURCE: 2 yr old Samsung Television screen lite blue wiht white lines
your television is going to need an internal repair. most likely in the power supply of the television. it would be best to unplug the television until it can be repaired. If you would like to repair the television yourself then please use our premium service so an expert can walk you through it. Or you can search for a local repair service using our local repair search engine.
Posted on Jun 28, 2008
Anonymous
  • 121 Answers
SOURCE: vertical bars both sides of screen visable with white background
do thy get lighter going from left to right? prob bad scan filter in hv. need tech unless your very handy.
Posted on Dec 05, 2008
Jim Epptech
  • 101 Answers
SOURCE: Hitachi 50V715
This sounds like your light engine is going out. NOT GOOD! It all depends when you bought your set and if its under warranty. I had the same thing with mine bought is 2004, light engine died in 12/08 and was out of warranty. Talked to the rep. said they knew about the problem. They replaced my light engine for free but I had to have a authorized dealer install it . I had to pay for the labor $300, Now I've got another problem with it shutting down and back on.(That's another story.) I would call Hitachi and let them know that you know they have problems with this. Keep trying they may replace your to. To buy one out right is $400 to $500 plus labor, some folks have paid $800 to $1400 , That's a shame. Hope this is helpful. GOOD LUCK!!
Posted on Oct 23, 2009
Harrie
  • 6740 Answers
SOURCE: my sharp model lc-20b9u-sm has a dark circle on screen
Without seeing the dark cycle myself it is difficult to guess what. I only can think of something hit the screen (ball?) or perhaps someone bumped into the screen?
If the bump was minor, it could become lesser.
Perhaps you should ask a technician to look, or take a picture from the screen, one when switched on and one switched off, but close to where the dark circle is and take the pictures to a tech.
Posted on Jun 26, 2014
What is the problem My samsung LCD TV picture went out and displays a grayish white background?
Hi
take a look in the picture line in menu.
open Samsung MagicAngle put it on off. My background became much clearer when I put it off
Jan 06, 2016 | Samsung LN-S3251D 32 in. LCD HDTV
Pink horizontal lines on samsung plasma tc when white background
I have this same tv and have the same problem, anytime there is a white background there is this pinkinsh tint in the middle of the screen, easily seen during those Apple commercials.
Aug 13, 2012 | Samsung 3D Plasma TV PN58C8000YFXZA...
The background light comes on when placed in the vertical. I need to turn it off to save battery life
The Auto Light feature of your watch has been turned on. To turn it off, press and hold the button that is on the bottom right of your watch for about 2 seconds. In the upper right of the face of your watch is a circle with some text on it. There should be a down pointing triangle in the upper right of that circle. Below that triangle there should be a dark mark before you turn off the auto light. After you hold the lower right button down for the 2 seconds that dark mark should turn off. The Auto Light feature will also turn itself off after six hours to help you to conserve your battery life.
Mar 25, 2011 | Casio Sport Watch White Resin Watch for...
GREY SPOTS ON BACK OF SCREEN NOTICEABLE WITH WHITE
Hi if your tv is a dlp it might be an issue with the DMD board Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
May 03, 2010 | Televison & Video
Vertical lines on my Samsung LNCT4665FX HDTV LCD
When you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical bars both sides of screen visable with white background
Dec 05, 2008 | Sony KP-53HS10 TV
Samsung Plasma TV - picture has 6 sections of horizontal lines
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Sep 18, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
I have a Samsung hdtv model LE32R74BDX. I have had it now for just over a year and appox. 6 month later we had 3 black lines to the left of the screen about 3cms apart. The lines are quite thick and start...
Mar 27, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Missing plastic circle: remote doesn't function
If the remote sensor cover is missing on the TV, the remote would still work but you may get other effects like the TV changing channels on it own.
This is due to stray infra red signals.
If it's not working at all I would suspect the remote control handset.
You can test it by pointing it at a digital camera lens and watching the display screen on the camera.
You should see white light comming from the remote when you press any of the buttons if it's working.
Digital cameras can see infrared.
Mar 13, 2008 | Televison & Video
Light Blue Circle in Center of the Screen
Hello BruceD,
What you may have is a magnetism problem. I would suggest that you try deguassing the CRTs first before looking into replacing the CRTs. You can have a TV technician perform this for about $50.00 - $60.00.
Thank you,
Shuttle83
Oct 27, 2007 | Hitachi 42V710 42" Rear Projection HDTV
Televison & Video Logo
29 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
