Question about Lands Phones
Would you mind telling me why my landline indicates there is "no line"? I have checked all connections and the phone is fully charged but no dial tone. This is the 4th attempt at contacting you.
Posted by margaret holmes on
5 Related Answers
Anonymous
SOURCE: bought phone EX18560 Series yesterday.
I have two older (2002) model cordless Uniden phones that require the handsets to return to their original factory bases. If they have rested on another Uniden base, even of the same model, there is no dialup tone. Replace to the original base and you should be back in service.
Posted on Aug 16, 2008
funkyjacob
Jacob McNamara
  • 76 Answers
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
Anonymous
SOURCE: Panasonic KX-TG1033 suddenly stopped working.
I just found this on another board, and it did work
One disappointing problem with this phone that I discovered only 74 days after purchasing the system: The base units "decides" for some strange reason "to go on a strike" and stop responding. This problem is documented on Panasonic's web site and is solve-able by simply disconnecting power from the base unit and re-connecting it. This works, but somewhat lowers the confidence in the "perfectness" of this product.
Posted on Jan 06, 2009
Anonymous
SOURCE: handsets wont work at all
it may be that the handset is registred to another base unit-
we had one base and one handset replaced by uniden, but the second (old) handset was still registred to the old base, therefore everytime we tried to deregister the handset it was looking for the old (replaced) base and of course could not connect and therefore wouldnt deregister. still havent figured out what to do yet
Posted on Apr 28, 2009
Anonymous
  • 37 Answers
Please disconnect your cordless phones from telephone jacks throughout the home. The "line in use" is say that you have a short on the line, or a phone off the hook. So disconnect lines, then replug 1 corded phone in to check for dial tone. If working, continue to plug in 1 phone at a time(rechecking working one each time) to find the equipment that is causing you heartache.
Posted on Apr 30, 2009
My Binatone Idect Edge single DECT has no dial tone, just a buzz. The display is working, but I cannot ring out, or receive calls.
Did you connect another phone to make sure that wiring is not a problem? Because you visually check it, doesn't mean that there is not a problem.
Apr 03, 2018 | Binatone Lands Phones
Have purchased this producct plugged it in no ringtone no flashing to indicate incoming call have operational line with dialing tone, help please asap as only line into work
I am assuming that you can hear dial tone on the handset, and you can make calls on the phone. If this is correct, then I would recommend contacting BT and getting the phone replaced with one that works. http://www.bt.com/help/home/landline.html
Apr 16, 2015 | BT Duet 210 Corded Telephone - White
Chat to customer agent landline reported to faults still not repaired
Where I live, my landline company is responsible only up to a "demarcation point" - this is a box on the wall near where the phone line enters the house.
There is an RJ11 socket on the box,
chat-customer-agent-landline-reported-2iujiwfvuy020nygunv3yc1j-5-0.jpg and the technician (or you) plugs a known-working phone into the socket, and listens for a dial tone. If there's no dial tone, then the tech takes corrective action - replacing cable, or confirming correct operation of the distribution box on the boulevard / utility pole, or contacting billing to reactivate the line.
If I dial 611 from my or a neighbour's landline, they'll typically have tech to my door in 24 hours.
Beyond the 'demarcation point' (ie inside my house), it is my responsibility to ensure the internal phone wiring is operational.
Check your local thrift stores for a replacement phone, if necessary.
Your local hardware store will likely carry a 'tone & probe" set, which will indicate if a phone socket is wired properly, and can be used to follow a wire through walls / ceilings / floors.
Pro3000 Analog Tone and Probe
Mar 17, 2015 | Lands Phones
I can't hear the other people on my plantronics cs 70 which is connected with my cisco ip phone 7941 phone
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
Good luck from Headsets Direct!
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Cannot order PPV using remote, meassage says, (must be connected to a working phone line) Which it is the landline is fully functional as we have phone service and can connect coumputer, Any suggestions?
Hello there! Daniel Busa with Dish Network customer service here. One thing i've noticed is if you have a phone line splitter on the wall jack they will tend to go bad often. Another thing you can try is pressing menu 6-3 go to connection hit select wait for it to finish, then go to dial out and hit select if that doesn't work check your line.
Oct 25, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Will not dial out on landline in the tone mode but
There's something wrong with the base unit that connects to the phone line. It's not sending any audio to the phone line, which would explain why tone dialing doesn't work and people can't hear you. (Pulse dialing doesn't need the audio tones so it will still work.)
I've never run across one doing this before. The problem is almost certainly some electronic failure, and I doubt there's anything you can do other than replacing the thing. If this is still under any warranty it should be up to the manufacturer to repair or replace it. If you got this from VoIP service provider, contact their customer service department.
Feb 03, 2010 | Philips VOIP3212G/37
My at&t landline has a dial tone but cannot call
check dialing mode matches what exchange is set to DTMF suspect phone is set to dec = decadic or pulse
Apr 17, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
I have 2 models # TM3111-2 One is plugged in to the phone line and to a power oulet. They both show charging but I don't get a dial tone when I pick up the reciever. My desk phone is plugged into the...
There is a solution which is easily implemented if you have discontinued phone service from your landline carrier.
1. Find the "block" where the landline enters your home and disconnect the wire which enters the block from the phone co.
2. At this point the wires in your home are "dead". If you had a dial tone before, you should no longer.
3. From your [email protected] router connect the phone line output to one of the regular phone jacks in the wall.
4. You should be able to now connect your vtechs to any outlet in your home --- regardless of the distance from the router.
5. You also can use your old regular wired phones if you wish to.
Aug 12, 2008 | Vtech Lands Phones
My landline phone does not work. I tested it outside on the company's jack and the phone works. I have 3 jacks in the house and it will not work on any of them, including the one I get the internet. The...
One of the phone handsets of the Panasonic KX-TG563 trio gives me static w/ dial tone and then shuts down or it gives me the message that "System is busy/Line in use" with no dial tone. If I get closer to the base unit it seems to work but w/ alot of static. The base unit phone works good and the other handset works ok too. The battery shows fully charged however, when I take the battery out to try a reset when I put it back in the battery indicator show very low. I tried switching batteries w/ the othe hand sets it doesn't help.
Thanks
Jun 07, 2008 | Lands Phones
Lands Phones Logo
81 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
