A lot of Kenmore toe grilles (kick plates) are just snapped into place on both ends. The photo is from another Kenmore model but it might help on yours
Keep in mind, Kenmore doesn't manufacture anything. It's just a house brand name for Sears appliances. Actually NexGrill manufactures the Kenmore Grill line. So contacting them 800.913.8999 is also a possible source for parts.
Hope this helps you and thanks for choosing FixYa. Happy Grilling!!
door lock error...door lock mechanism broken,,,replace door switch,,,if your lock out remove toe panel and reach up and pull tab,,always unplug first...good luck
need complete model # to give correct help but most kenmore sxs ref / the defrost timer is located in the control panel . two screws to remove an un plug it .. reverse to install .. some older models are locaded behind the toe grill . same two screws.. mm
Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
turn off power an back on / if no change remove the toe panel and the tech sheet will be there . it will tell you what the code is and how to correct most .. mm hope this helped. pls leav feed back.
