Cant seem to log inn though I know username and password
Posted by Joan Beaton on
Larry Ng
  • Computers & ... Master
  • 6,019 Answers
Where, add a noun
Posted on Jan 18, 2020
5 Related Answers
Anonymous
  • 556 Answers
SOURCE: i cant access my router(EDIMAX BROADBAND ROUTER)
Warning the following instructions are likely to RESET THE ENTIRE CONFIGURATION OF THE ROUTER and you will need to reenter it completely. Do not follow these instructions unless you are prepared to reconfigure your router completely from the factory defaults. I am not sure but be careful or consult with EDIMAX support before proceeding.
note the following is from the http://www.edimax.us/ website follow technical support and click
BR-6104 / 6104W / 6104P
Then
If I forget my password, what can I do?
I hope this helps.
Posted on Dec 06, 2007
Anonymous
  • 16 Answers
SOURCE: cant login to router
When in doubt double check your work. You held the reset button down on the back of the router for long enough for the lights to go out then start blinking again? Then you went to 192.168.100.1 in your browser and tried admin for your login name and motorola for your password? If you did all of that and it's still won't accept your login try to power the router off for at least a minute by pulling the power cord and make sure you clear your browser cache before trying to access the default gateway address in your browser again.
Hope that helps!
Jill
Posted on Nov 30, 2008
Chuck
SOURCE: cant log into yahoo mail
I am having the same problem. Tried everything they suggested and nothing yet. As far as I am concerned, it is a problem with their systems.
Posted on Jul 28, 2009
John P Griffin
  • 89 Answers
SOURCE: i cant log into the admin account on 192.168.1.1
press the RESET button on the back of the router and hold it in for 30 seconds. Use a pin. Once you have reset the router it will default to a generic user name and password. The default user and passords are admin admin or user user
If you still have trouble call support
Telephone (North America) 877-ZHONE20
Posted on Aug 03, 2009
Anonymous
SOURCE: Problem
point your browser to -> 192.168.10.1
default user and pass is:
user: guest
pass: guest
(i have tried posting this solution 5 times now and it never shows up!)
Posted on Mar 25, 2010
How do I connect my wii to hotel wireless
This is on the end of the hotel. Ask the front desk how does one connect to the wireless. They most likly have a username and password you have to enter in the web engine on your wii.
Jun 29, 2014 | Nintendo Wii Console
I cant log in my wireless device dlink on http://192.168.0.50/ i want set the password and i cant
the first time you access http://192.168.0.50 it will ask you for username and password. Type the default username and password. If you don't know try one of these:
Username: admin
Password: password
Username: admin
Password: No password (just hit enter after you type the username)
Username: admin
Password: admin
Dec 07, 2012 | D-Link Dlink Airplus Xtreme Dwl-2100ap...
How do I find my wep key? I cant remember it and cant get online wireless with out. I did go to http://192.168.0.1/login.asp but I cant seem to log in there. Please help.
Try to access 192.168.0.1 once again. Try to use "admin" for the username and "motorola" for the password. If "motorola" doesn't work, try "password".
Sep 03, 2011 | Arris SURFboard SBG900 Wireless Router...
Left my old company and took my personal computer with me. However I can't get it to work because everything is lock out by old company and they won't remove their rights??
You have two options that may work. Can you log in with your old username and password to the system? If so, and if you have sufficient rights with that user account, you can remove the domain and join a work group. **Before doing that, create an administrator account that you know the username and password for.
The second thing is to see If you can log in locally with that administrator account? If so, then you can access anything on the hard drive, and you can change the domain to a work group. On the log in screen, you should see username, password, and domain. Change the domain to the local system, and use administrator to log in, if you are lucky, the password could be blank. Or maybe (not likely though, they would give you that password. If not there are ways to hack it.
If you get to that point, or if you need assistance trying my suggestions, please let me know.
Thanks
Mar 13, 2010 | Dell Dimension 5150 Intel Pentium 4 w/HT...
I cant log in with my username and password
Reset the router to factory defaults by putting in a push-in in the small hold at the back of the router. You should then be able to login using the default password. Default password should be in the user manual.
Dec 05, 2009 | Arris SURFboard SBG900 Wireless Router...
I cant logging in
Im having the same proble, and it started when i moved into a new city. I put in the correct name and password and camfrog just never gets past the "camfrog is logging in" part.
Sep 10, 2009 | Intel Computers & Internet
Disabling firewall?
by default, you can get to the surfboard configuration page by http://192.168.100.1. username: admin / password: motorola
username and password are case sensitive.
if you dont know the password better get it from your roommate to avoid resetting the modem back to factory defaults. if there's no other way to retreive it you can reset it by pressing the reset button on the back of it for 5-10sec.
after resetting, according to the manual, the modem might need 5min to 30min to sync again with your ISP.
Jun 05, 2008 | Arris SURFboard SBG900 Wireless Router...
Forgotten password on login page
Try looking on the modem itself, sometimes they have their default username and password written on them. Try combinations of "user" or "admin". eg username: "admin" password "admin"
if these don't work and you don't know why you can't log into your modem, try resetting your modem using the reset button on it (or holding the power button for 10-20sec) and then try the above suggestion again.
If you still can't login, write back with your modem make and model number.
Jan 09, 2008 | Computers & Internet
Cant sign in to my account
What account are talking about?  Your dial up ISP?  Windows xp log in screen??
Oct 15, 2007 | Computers & Internet
My emachine wouldnt let me log on even though im using proper username and password
Please elaborate more on what you mean by it would not allow you to log on discribe in detail what it actually is doing so I can know how to help you. For instant is it whirling at the bios screen and continuing doing this?
Sep 09, 2007 | Novell Nsure Audit 1.0 Secure Logging...
Computers & Internet Logo
k24674
