Question about Car Audio & Video
We have no sound from radio or from the CD player. The unit was working. Radio shows it picks up stations CD shows it loads up but no sound .
5 Suggested Answers
Anonymous
SOURCE: pb10-cd
Hatrack thanks again! I dropped my bosch radio from about 8 ft and holy crap it works again just like NEW!
Posted on Feb 22, 2008
sewell94
SOURCE: GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Posted on Aug 07, 2008
Jonah Oneal
  • 14092 Answers
SOURCE: 1999 Mercedes CLK radio antenna
look at antenna wires make sure every thing is in contact.if all is good.sound like problems in the sound amplifier.in radio.
Posted on May 07, 2009
r_mcalhoun
ray calhoun
  • 166 Answers
SOURCE: my saturn vue radio does not work. CD player works
it probably in the radio it self .some of have 2 fuses check them.better check all fuses. good luck
Posted on May 09, 2009
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Posted on Jun 28, 2009
NO MUSIC JUST STATIC CD PLAYERS WORKS GOOD SOUNDS GREAT BUT NO STATIONS PICK UP ANYTHING
It sounds to me like the radio antenna has disconnected from the back of the radio head unit. Pull out the radio to check and see. I hope this helps, if not, let me know and ill try to assist you further
Dec 11, 2010 | 2003 BMW 325
I have a bose wave radio and cd player the cd
you sure have a problem with your cd pick up unit or servo drive,for that must bring it to your local repair shop
as for the poor recepcion olease try a better antena
Dec 18, 2009 | Bose Wave Radio
Cant pick up any radio stations after battery was changed
probably need the anti-theft code to get the radio working again
Jul 15, 2017 | Sony CDX-M600 CD Changer
Sansa clip 2mg fm radio not putting out sound
Go into the Settings menu of the Sansa, and change the region to "World" if you live outside the US, and change to "United States" if you live inside the US. Then, go back to the Radio mode and see if there is an icon that looks like a block (technically, a "Stop" sign) - if there is, press up on the clickwheel - it will get your radio off of pause mode. You radio should now work again.
Mar 30, 2009 | SanDisk Sansa Clip MP3 Player
I have a 6 CD Changer but dont know how to use it?
This is an older way that makers of CD changers used to get CDs into cars that didn't have them.  This is what they tried to get people to by them.  I was never a fan of this system as the sound quality was never better than listening to FM radio.  There is a unit in the car, usually under the dash behind the glove box, that the CD changer is plugged into.  This unit has the FM antenna from the car plugged into it, and then a cable that is the same as that coming from the antenna going from the unit under the dash plugged into the FM antenna jack of the radio in the dash.  All this unit does is take the digital, high quality sound from the CDs, transmit it on an FM frequency (usually low on the FM band 80s, 90s or low 100s) and then you tune the radio into that FM frequency to get the sound form the CDs.  Problem is, the sound quality was only as good as FM radio.  A pretty poor way of getting CDs into cars.  But they sold millions of these things.  If it isn't working, the wiring may have come loose, the fuse to the unit under the dash might be blown, or something is disconnected.  if you go all through the FM dial, 0.1 at a time and don't hear it, it is time to get under the dash near the glove box and poke around.  Good luck.  If it were me, I would take all this gear out and put a new CD/MP3 player where the factory radio currently sits.
Jan 02, 2009 | Marantz ZS5300 6-Channel Amplifier
Pb10-cd
You're welcome in advance.
This particular unit was advertised to be unbreakable when dropped due to its shock absorbers; therefore dropping it will fix it.
Oct 24, 2007 | Bosch PB10-CD Radio/CD Boombox
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
