SOURCE: What is the remote code using AT&T U-verse for
If you look into the code list from AT&T and you dont see olevia listed.. then that means the remote is never going to work with an Olevia Brand. Because the remote is pre program already from the manuf. and you cant add any codes to it.. unless you call at&t and see if they carry any updated remotes for u-verse that has olevia on there list of codes..
The only other way to get around that is to purchase a remote that was made by Olevia called RC-LRN (learning remote) This remote will work with the olevia and its able to program and learn from other remotes you might have.. This company called Amergence Technologies sale this remote you could contact them at 866-965-3842
SOURCE: Olevia 537-B12 goes off every 20-30 minutes. How
Both picture and sound go out at the same time?
First place to look will be the power supply section, second place will be the backlight inverter board.
Need to look for bad caps, cold solder joints, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: Where can I get a replacement LCD screen for
I assume your sure your panel is defective. I checked with all my parts providers and could not locate a panel. Normally the panels cost as much or more than a new set making it uneconomical to replace them. For instance a 40 sony panel will run 1100.00 and the tv around 850.00. Sometimes you can find used panels but always the risk they dont work. Most televisions on ebay that are selling for parts have defective screens. Sorry... If your not sure your panel is bad list the symptom and we can go from there..
SOURCE: tv on off button turn
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?) Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourself it will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate it accordingly. Good luck.
SOURCE: Olevia model 537-b12 loses the
if you look closely can you see any picture what-so-ever? grab a flashlight and check to see if you see a very dark image on the screen. if so you need to check voltages coming from power supply to the inverter board - if the voltages are good - order inverter boards - if you can see the backlights on - check your Main and tcon boards..
thanks,
michael
