Question about Pioneer Car Audio & Video
My Pioneer PDM410 6 disc changer won't read. Lense is still in place. Any ideas?
5 Suggested Answers
lars ahlsen
  • 47 Answers
SOURCE: Pioneer 6 disc PD-M455
Hello...if you can try to clean the laser lens whit a smooth cotton pin it may be dusty,,i have had the same problem...don't use any solvent just the pin very carefully,,,maybe you can use a mild solution made of hand dish solvent... and dry clean after...alternative use a cd.cleaning disc...Good luck Ron
Posted on Mar 11, 2008
Elliot
  • 108 Answers
SOURCE: Panasonic CD Changer with Pioneer reciever
Panasonic CD changers have a specific plug in that will not work with the Pioneer head unit. The Pioneer uses the IP-BUS plug. You will also not be able to convert the unit to work because the data between the two cannot be controlled and you won't have the ability to use the units together.
Posted on Sep 19, 2008
Anonymous
SOURCE: my delco disc changer stopped working,It reads cd changer error
disc is stuck in Delco 6 Disk Changer
Posted on Feb 03, 2010
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: Hi, my cd player will
you need to purchase a laser disk cleaner to clean the laser they are available from almost all electronics retail outlets
here is a picture of one
have a great day
please rate this advice if it helped
Posted on Jan 03, 2011
Testimonial: "Thank you so much for the advice! It was very helpful! "
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Where can i find an
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=Pioneer+PD-F606&uuid=A13098020997241
Posted on Jul 04, 2011
Cd changer shuffles but won't play
Check its laser pickup assembly for any dirt or dust. Click here for more details
Sep 04, 2012 | Pioneer PD-M403 6-Disc CD Changer
My Pioneer PDR 555-RW keeps reading Mon1 or Moni when I try to record my CD from my mixing board. I need to send this wedding music, and it is trapped in my board. HELP!
That's just a MONITOR indication. It means you can SEE the audio from the selected input on the record level meters for adjustment or other reasons. It won't prevent you from recording. Set your levels then hit RECORD, let it set itself up and calibrate to the disc, start your source and hit Play or Pause to start recording to the disc.
May 14, 2011 | Pioneer PD-R555RW CD Recorder
I have a pioneer 6 disc changer that won't spin the disc, thus giving the error of no disc. I took the cover off and it doesn't look like the laser eye is on. and the spin motor doesn't engage. Any...
pioneer cd players have the common problem of losing their laser lens due to the glue that holds it in place going brittle over time. try shaking the player from side to side and upside down to see if you can hear the lens rattling about. if you recover the lens, very carefully slot it back in place and apply a tiny drop of glue (NOT SUPERGLUE) to the outside edge of the lens taking care not to get any on the focus area and leave to dry. all should be well after this. i find UHU GLUE in the yellow tubes do a lasting fix but don't use SUPERGLUE as the fumes will coat the lens.
hope this helps?
Sep 26, 2009 | Pioneer PD-M603 6-Disc CD Changer
Display reads No Disc despite all the discs checking out.
Hi, the optical lens assembly has failed. this is triggering the (no disc) error code. you will need to replace this failed optical assembly.
May 29, 2009 | Pioneer Car Audio & Video
Pioneer dvr3100
hi.. the problem is not with ur DVD-RW disc... Its in ur device.Might be the device is unable to read the disc.. so better try to clean up the lense of ur device with the help of lense cleaner... it will remove of the dust so that it will be able to read the disc...
thank u
Feb 01, 2009 | Pioneer DVR 105 DVD-RW Burner
We just bought a used car with a Pioneer CDX-FM61, maufactured
I dont know myself but the first thing that i would do would be to pull the cover off and look to see if there is anything happening inside. It may be something as simple as the carrier jamming, the cd motor isn't turning or a dirty lense. Try resetting it too, if you can find a button (or unplug it for a few minutes).
Just a suggestion.
Niels [email protected]
Jan 22, 2009 | Pioneer 6CD CHANGER
Won't read discs
Discs Must Be Loaded Label Side Down.
Sep 07, 2008 | Pioneer PD-M603 6-Disc CD Changer
Pioneer cdx 12 disc changer
According to manual code simply means electrical or mechanical fault - not extremely helpful.
Try to disconnect and reconnect power and it perhaps will reset the problem.
Feb 03, 2008 | Pioneer CDX-FM1289 12-Disc CD Changer
Pioneer PD 8700
I think you are right and glue has got on the lens blocking the reading of the disc. If you can remove the glue without scratching the lens, it should cure it. Otherwise you need a new lens.
May 17, 2017 | Pioneer Audio Players & Recorders
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Sumeet Sodhi
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
