Question about Cameras
Date of manufacture of Chrysler battery imprint om top: 3L29F54
Posted by John Rossi on
2 Related Answers
Anonymous
SOURCE: date/time imprint. Coolpix 2100
To remove date imprint. This is the solution provided by Nikon more than a year ago. Switch on> set to green>menu>scroll down to Date Imprint.press centre/right on multi selector>select 'off.' Job done
Posted on May 01, 2008
  • 102366 Answers
SOURCE: Cannot imprint date
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Posted on Aug 25, 2012
I would like to turn the date stamp off... I do not like it in the pictures
Using the Capture Menu
The Capture Menu allows you to adjust camera settings that affect the characteristics
of the images and video clips you capture.
1. While in Live View or Playback, press , then use to highlight .
2. Use to highlight a menu option, then press to display the menu option's
sub-menu.
3. Use to highlight a setting, then press .
4. Press to exit the Capture Menu.
For on-camera information about an option, use to highlight Help... in the option's
sub-menu, then press .
In the capture menu goto
Date & Time Imprint Imprints date in lower left corner of image.
Off Default No date or time imprinted on the image. (this setting)
Date Only Date permanently imprinted.
Date & Time Date and time permanently imprinted.
this should fix your problem
I have a Nikon Coolpix s560. I want to shut off the date/time stamp imprint that it makes. I take pictures of my art with it and cannot have time stamps in the picture.
Welcome to FixYa,
You can disabled the Date Imprint. In this option you can print your pictures without the date and time printed on it.
All you have to do is set the Date Imprint on its default setting or setting it on OFF
Just go to Set up Menu and look for the Date Imprint and set it to OFF.
There are other option where the Date Imprint will be disabled.
- When the Continous Mode is set to Continous or BBS
- When the Scene mode is set to Sports, Museum, or Panorama assist.
- When movies are being recorded.
Hope this information will help you and can answered your question.
Thank you for using FixYa.
Mar 10, 2011 • Cameras
2answers
How do you change date imprint to on
Select Setup, then select "Date Imprint". It's in the "Date Imprint" subsection of "The Setup Menu" section of the manual (pages 95 and 91 in my copy).
If you need a manual, you can download one at
http://www.nikonusa.com/pdf/manuals/coolpix/CP4800_en.pdf
3answers
I want to set my time date setting so it will be recorded on my pictures. Thank you [email protected]
You will probably find that this not possible. The date and time are recorded in the EXIF information with each photograph all the time but not actually in the picture at all.
How can I get date stamp to my Canon G10?
From the manual:
This camera does not allow you to insert the shooting date into an image while shooting (date stamping). However you can use the following method to imprint the date while printing.
  • Set with the camera's Digital Print Order Format (DPOF) function. Set [Date] option to [On] in [Print Settings] in the Print menu.
  • Connect the camera to a printer and imprint the date. See the Direct Print User Guide.
  • Insert a memory card into the printer and imprint the date. See your printer user guide.
  • Use the supplied software. See the Software Starter Guide.
You can download the manual and guides and more from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_pro_series/powershot_g10#BrochuresAndManuals
1helpful
Procedure to set date stamp on Canon Powershot G10
From the manual:
HOW TO MAKE DATE STAM ON CAMERA CANON G10
From the manual:
1helpful
How can I turn on the date stamp on my Canon G10?
From the manual:
How do i remove the date , time, 101nikon 1939 jpg on top of the
This will always be displayed in your camera. However to choose what will imprint on the pix :
Turn your dial to SETUP and select DATE IMPRINT. Then select OFF (nothing will imprint on pix), or DATE (for just the date to be imprinted), or DATE and TIME (for both time and date to be imprinted)
2answers
Date/time imprint. Coolpix 2100
This can be done with photo editing software like photo shop on you computer. hope this helps. it the photo was already taken with the time stamp on at the time of the photo it will be on the photo and the only way to get rid of it is software. Hope this helps. please let me help you before you leave a thanks for tring feed back.
Cameras Logo
Top Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Camera Expert? Answer questions, earn points and help others
