Question about Samsung Televison & Video
Samsung television, when I power it on I hear sound, no picture. I have to unplug the television then replug it for the picture to show. This has been getting progressively worse.
5 Suggested Answers
HDTV GURU
Jay Henderson
  • 261 Answers
SOURCE: Problem with HP-T4254 Samsung television model
I think you have to have something plugged into video inputs or RF INPUT for sound to work. Otherwise you get a blue screen and it says no input. or not available. Does this set have an off air HDTV tuner? IF it does, try hooking it up and see if you get sound then. Good luck and that should solve you problem. If not, reply back and we will continue with troubleshooting. Thank You Jay
Posted on Jan 31, 2008
Anonymous
  • 61 Answers
SOURCE: power surge-no picture or sound, just red blinking power light
Any malfunction associated with a blinking redlight usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Posted on Sep 13, 2009
Jack South
  • 195 Answers
SOURCE: Samsunb 4051: TV screen turns off sound stays on.
Most likely this set has an "integrated" inverter, as most samsungs do--and this DOES sound like an inverter problem. Make SURE thought, there are no more bad "10 volt" caps on the power supply...ALL of them need to be replaced no matter HOW they look.
Posted on Oct 15, 2009
Chi Chu
  • 8457 Answers
SOURCE: Samsung HCL4715W red light indicator is on, but TV does not work
Ur backlight video board is dead,must replaced.
Posted on Dec 10, 2009
Anonymous
SOURCE: I HAVE SAMSUNG SGH-U600 WITH SOUND PROBLEM
hi :)
Well, your problem is mine problem, and the problem of all U600 with some use. The problem is the Flex Cable that connect to LCD is "broken". So, you just need to go to the Samsung office (if you have guaranty) or do the same like me... I have no guaranty left so, I will buy a new flex cable in ebay, and then I will make the changes by myself... but of course, you shouldn't do that if you don't understand nothing of that... :P I'm just waiting a letter from ebay to complete my account and "Voila" :) If you just need to know how to open your phone to change, there are a really good video on youtube about that ;)
Good luck ;)
Posted on Jan 03, 2010
Why does my sharp tv 32k-x1000 picture turn offand wont come back on unless i unplug it then replug in outlet
Main system control memory IC fault. Replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Sharp 32K-X1000 TV
Re:toshiba 55h70 tv i unplugged the tv to paint. when i plugged back in a wk later i have no picture or sound. nothing. can't access the menu - completely dark screen. the red lite "on" button...
I would check the fuse on the main board. Check the Capacitors on the Power Supply board. Seeing that you unplugged it and replugged it in you might have bad caps that were weak to begin with. Please learn how to safely work on a TV before attempting . Even when a tv is unplugged it has enough power to kill you. Discharge all Capacitors first. make sure its unplugged of course.
Jan 06, 2011 | Toshiba 55H70 55" Rear Projection...
Power on but no picture or sound.
Tries unplug,replug the tv set see if reset itself.If it don't must take to the shop u short somthings out.Must troubleshoot and replaced the parts.
Nov 05, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Oct 15, 2009 | Samsung LN-S4051D 40 in. LCD Television
4665 samsung has sound but no picture
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent.
Jul 28, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung HPS4253 won't turn on all the time
i would suspect the main board "if" the display lights...., look for a dull glow when you turn it on.turn it off and back on ..look again. do you get a menu when you hit the menu button on the samsung remote ? if you see any sign of light and do not see a menu replace the main board.
Feb 27, 2009 | Samsung HP-S4253 Television
Samsung flat tv has no picture
Try a "hard restart", which simply means unplugging the power cord of the TV , and replugging it 4 hours later. This technique is useful for reprogramming the electronics of the TV. Hope it works for you.
Jun 29, 2008 | Samsung Televison & Video
No picture
we had same problem......we just had our whole panel on our samsung panel changed
Jan 23, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
Ekse
