Question about Humidifiers
Stulz suprasteam humidifier in fault showing EC on the display. What does this mean?
Posted by Julie King on
I have an essick humidifier and it keeps flashing CF but it continues to run. What does the CF mean.
Check Filter Indicator The ability of any humidifier to efficiently supply humidity output relies heavily on the condition of the filter. As the filter loads with impurities it gradually loses its wicking capability. When this happens, moisture output is reduced and the humidifier has to work longer to satisfy the selected setting. This humidifier has a check filter reminder timed to appear after 720 hours of operation. When the Check Filter (CF) message is displayed, disconnect the power cord and check the condition of the filter. If a build-up of deposits or severe discoloration is evident replace the filter to restore maximum efficiency. The CF message is reset when the humidifier is plugged back in.
Dec 03, 2017 | Humidifiers
Showing Error Code E1
If you wish to get some details; check the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Aug 31, 2016 | Fisher Paykel Fisher & Paykel SleepStyle...
When i plug in my sunbeam humidifier I get an er on the screen what should i do
Impossible to know without communicating with Sunbeam. "ER, ERR" and the like are normal failure mode displays whenever the unit can not operate as normal. As there are electronic components involved, a failure of any one will fault the unit.
And it could also be something as trivial as a buildup of scale on the water sensors. (Have you tried a thorough cleaning of the unit?) I would first try soaking the water chamber in white vinegar for several hours.
It that does not fix it, it's probably done for.
Jan 03, 2016 | Sunbeam SCM631-UM Cool Mist Tower...
E3 Error Message
E3 indicates a sensor fail - most probably the humidity sesnsor. Or it could be a fault in the display itself. Are all the functions working properly?
May 28, 2013 | Humidifiers
I have lost my manual. readout on the digital display is CF. humidifier operates fine. what does the display CF [email protected]
It means Change Filter.
However, assuming that you have done that in the recent past, you probably want to know more. I'm not sure how this actually works (that is why it shows CF). I saw it for the first time after 2 or 3 years of using my humidifier. (And I had just changed the filter a week or so previously).
You may have to turn the unit off/on or even unplug it to clear the message, then it should operate normally.
Nov 05, 2010 | Emerson HDC12 Humidifier
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
I HAVE A HONEYWELL CHRONOTHERM 3, THE DISPLAY SHOWS THE TIME & -AC. I THINK THE UNIT IS FIRED. PLEASE ADVISE.
you have no power to the thermostat check to see if the furnace switch is on or if the blower cover is on properly.
Oct 17, 2009 | Honeywell Power Humidifier: Furnace...
My ge humidifer AHH140LK61 is showing a "P1" readout
Unit is defrosting – Allow the unit time
to automatically defrost. The error will
clear after the unit self defrosts.
Dec 02, 2008 | General Electric AHK30LK Humidifier
Kenmore 14416 Humidifier keep Showing CF on display.
Contact these guys and they should be able to let you know where to get a user guide. http://www.sears.com/sr/misc/sears/custs... unfortunately they dont seem to have them online - please complain to them in the hope they might make this available instantly Hope This Helps :)
Mar 09, 2007 | Kenmore 14416 Humidifier
Humidifiers Logo
Top Humidifiers Experts
Tom Chichester
ray gallant
STEVE
Are you a Humidifier Expert? Answer questions, earn points and help others
