Question about Gemini Televison & Video
GEMINI cs220 PRO. I CAN'T SWICHT IT ON. COULD U HELP ME?
In my Gemini CS220 Pro, I press the button, it lights up for a second and is heard as it turns on, but instantly turns off. Tried to open it but i needed especific tool just to release screws. so I’ve just light checked, mainly if plugs OK & conirmed not stuck caps or bad placed bids. Sometimes, after several tries it suddenly switches on & runs perfect as less you turn it off again. Problem it is used in a restaurant and can’t take a chance if today switches or not, just depend in luck!
Posted by Pep Owned on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Won't Turn On/Charge
when that happened to me it could have been caused by two possible problems:
1) water damage. If you know it's not water damage, it still could be because if you had your phone in the bathroom while having a shower, steam can seep in and if it's one thing I noticed about chocolate flips they get water damage really easily.
------>>> If that is the case then you have to take your battery off and take a really fine ground sand paper and rub along the contacts (like the copper that is on the battery and the phone that touch when you put ur battery in) and that will rub off any kind of oxidization (rust) and possibly make your phone work. It happened to mine and I did that and it was successful
2) you could not be turning your phone off regularly enough. Technically, you are supposed to turn your phone off every night when you go to bed to give your battery time to re-vamp. Also, I was speaking with a rep from telus and they were saying that you should also turn your phone off during the day, just for a minute then turn it back on again and apparently it recharges the battery as well.
Hope this helps!! It only comes from personal experience so it all depends on the reason why it's doing that.
Posted on Dec 09, 2007
Anonymous
SOURCE: MacBook Pro Black screen and shining sleep indicator
is the battery fully charged? try plugging it in then press the power button again.
Posted on Jan 10, 2008
Mameds
SOURCE: error code 6502 on MP510
why error 6502..........?????
Help me pls.........!!!!!!!!!!!
Posted on Jun 12, 2008
Anonymous
SOURCE: Steam Vaccum won't switch on
it sounds like your thermal fuse went out and u have to open it up ant test the fuse with a multimeter...I had the same problem and had to replace the thermal fuse...I ordered a fuse(sf188e) from ebay...cut the old one out and soldered in the new one...hope this helps.
Posted on Jan 06, 2009
Anonymous
SOURCE: only power light will power on for few seconds then flashes.
Does the main lamp light at all? It sounds light a cooling fan failure. If the fan iis not working the the main lamp will not turn on and the power light will flash.
Posted on Jan 08, 2009
Hie lost license key gemini io firstmix pro please help
Isn't the license on the software, not the Gemini unit?
Here is the website for Cross DJ Mixvibes software. In case you can't find your copy.
There's a free version, a $39 version and a $89 version.
Cross DJ app for Mac PC Free and Pro versions By MixVibes
Sep 07, 2016 | Computers & Internet
Gemini FIRSTMIX PRO can't volume on master output
Dear Joshua Chan, I suspect there is a problem with your sound card driver. Could you please try to use some free driver update software and see if this tackles the issue?
Jan 26, 2014 | Gemini DJ Gemini Firstmix Pro DJ Software...
Inconsistant milk froth temperature from gemini cs220 machine
http://www.skiilashes.com/3d-mink-fur-lashes/3d mink fur lashes 3D MINK FUR LASHES MANUFACTURER-SKII LASHES Best sellers hot fashionable 3d mink fur lashes with custom eyelash packaging, come to shop the best quality China 3d mink fur lashes for eye makeup. Worldwide shipping and fast delivery directly from our lashes factory. We make top quality 3d mink fur lashes market in China, if you wann wholesale price, inquiry us.
Nov 30, 2013 | Coffee Makers & Espresso Machines
Need to replace wireless antenna connection on Gemini RM700. Can't find replacement parts.
Did you ty to contact gemini? If they wont sell you one. We here at Pro Line Music are gemini dealers and I will try to order it for you. 2157368055
Jul 15, 2011 | Gemini Sound Products UF-1064M Microphone
Gemini SV-2200
first off you dont even own a turntable. Second, dont talk about something you dont know about!
Mar 19, 2008 | Philips gemini SV-2200 Turntable
Webcam driver
i have loose my gemini webcame driver i want to downlod driver please offer me
Jan 26, 2008 | Computers & Internet
Televison & Video Logo
32 people viewed this question
Top Gemini Televison & Video Experts
ray gallant
Tom Chichester
Are you a Gemini Televison and Video Expert? Answer questions, earn points and help others
