Question about Watches
How do i change my jyou smart watch time format from 24 hour to 12 hour format?
Posted by Tim Fresh on
Bahi-eldin Yaser
    Problem Solver:
  • 11 Answers
From the application in your phone
Posted on Mar 19, 2020
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: 24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
Posted on Jul 05, 2007
Anonymous
SOURCE: Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
Posted on Mar 17, 2008
David Tolond
  • 2501 Answers
SOURCE: coleman watch Model No. 40-328 How To change from 24 to 12 hour
I couldn't find the instructions for your watch but as watches tend to have similar operating characteristics, try this:-
Press the mode button until you come to a message that says something like "12hr" or "24hr" or something that indicates display change.
Then press one of the two buttons on the right to change to the display you require.
Some experimenting may be required!
Posted on Feb 03, 2010
Anonymous
  • 714 Answers
SOURCE: how to change from 24 hour to 12 hour on g shock
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 19, 2010
Anonymous
SOURCE: How do I change my Casio twin sensor alti thermo
Press and hold the top left button for 2 seconds to go into the time adjustment mode.
While you are in this mode press the top right button to switch between 12 hour and 24 hour modes.
Press top left to return to normal.
Posted on Feb 21, 2010
How do I change from 12 hour format to 24 hour format ?
In mobile u can go to setting>date and time> there is is boxx showing time format uncheck the box to 12 hour format
Thanks...
Jul 04, 2016 • Watches
How to go from military time to standard time for the armitron M721 watch?
just change your time format settings from 24-hour format to 12-hour format.
Steel Leopard Shark watch manual
To set the hour format, press S1 button
to toggle between 12-hour and 24-hour
format. The P.M. indicator may be
displayed to indicate the time period
12:00 A.M. - 11:59 P.M. in 12-hour
format.
11.To set the calendar format, press S1
button to toggle between M-D (monthdate)
and D-M (date-month) format.
12.After finished making all the settings,
press S2 button to confirm...
Dec 25, 2013 • Watches
1helpful
12 hours early
Try this:-
First set the watch to 24 hour format rather than 12 hour format.
4helpful
I have a g7900 gshock watch. on the little manual says toggle 24 hour/12 hour i have to press button D, but it didnt work out. i want my time to be on 12 hour format. please help me with the steps.. thank...
Bottom right button will change watch from regular time to military time. Just one push is all it takes...if you have the g-9700 the button color is red...hope this helps.
Timex 1440 sport indiglo 50m convert from 24 hour clock to 12 hour clock.
There are several models of your watch not all of which appear to have a 12/24 hour display format.
Try this extract from a manual; press the MODE button six times to enter the 12/24 adjusting setting and then use the START/STOP or SPLIT/RESET button to change the time.
Press the mode button to return to normal operation.
Dec 06, 2010 • Watches
1helpful
How to adjust the time on a CASIO W-59 watch
Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
Sep 27, 2010 • Watches
13helpful
How do I change my Casio twin sensor alti thermo watch from 24 hour to 12 hour format?
2answers
Roxy 80' W056DR
Possibly, you could push the hour-setting button through either the military or standard time setting, i.e., there are actually 48 "hours" you can set your watch to and you need to cycle through enough of them to reach the standard or military hour you want.
27helpful
3answers
Timex Indiglo WR 30M
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
WATCH IS SET TO 24-HOUR TIME.
Watches Logo
Top Watches Experts
Lisa Christine
Lisa Christine
john h
Are you a Watch Expert? Answer questions, earn points and help others
