Question about The Computers & Internet
I have a 5.0 bluetooth transmitter and i installed it in the usb port on my tv.i cant read the instructions because the damnd printing is to small
Posted by William Moore on
Russ Hill
  • The Master
  • 4,057 Answers
Magnifying glasses help. also make sure the usb is able you be used in this way some are just for usb drives. 5v 1amp.or even 0.5 amps.
Posted on Jan 15, 2020
4 Related Answers
Anonymous
SOURCE: GE Bluetooth Transmitter - pairing problems
There should be a button on both the headset and the reciever. Y ou must hold them in intel they beep or start flashing.
Start with the transmitter first then headset.It may take a little playing around but you should be able to figure it out.
Posted on Aug 25, 2008
Anonymous
  • 239 Answers
SOURCE: canon mp460 wireless printing
you need to in stall the drivers on your computer for the printer. and make sure you phone is not connected to the printer at the time you are trying to use it with your computer as this can cause problems to.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 01, 2009
martin-r
martin-r
  • 151 Answers
SOURCE: I JUST BOUGHT A iwave
You don't need a usb port for mp3 playback, simply burn some mp3 files to a cd - not like an audio cd but a data cd (drag and, drop and burn the same way you would burn pitures to a disk) you will find that you can fit 5-10 whole albums on one disk.
Enjoy & good luck.
Posted on Jan 18, 2011
e_hudson
TechGirl
  • 496 Answers
SOURCE: LCD screen is cracked and computer has only 2.0 usb ports no HDMI or Bluetooth how can I connect to another moniter or LCD TV
No it is not possible this way. Look for a VGA port.
25618467-cbt13vi4zbmnff1d5zdl02jb-2-0.jpg Not always blue, but it has 15 pins. Your monitor or TV will need to have the same connection.
Posted on Mar 30, 2015
Testimonial: "this is an all in one computer and has no VGA port either is it possible to install Bluetooth and connect that way"
Can I use the USB service port to power a Bluetooth transmitter
Hi Frank,
If you are referring to using your TV as the USB port... you cannot. It's strictly for service. I have tried as well and it won't recognize it. It's strictly for servicing.
Mar 01, 2016 | Sharp LC-46SB54U LCD TV 46 inch Class,...
How do you connect logitech a-0006 via bluetooth ? lost usb reciever/transmitter.
If you do not have the Bluetooth dongle (plugs into a USB port) you should contact Logitech for a replacement. Alternatively you can also look for one second hand via craigslist, ebay, etc.etc.
May 04, 2014 | Logitech Radio Communications
I cant enable bluetooth on my pc
If it is an old laptop, it may not have come equipped with a Bluetooth device. You can buy an external Bluetooth transmitter which would plug into the USB port.
Mar 28, 2014 | Computers & Internet
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
I have a toshiba tv with usb can i plug a blue tooth dongle in to make it connect it to my lap top
No you cannot. The usb port on your tv is for viewing pictures and playing music. You would need specific software installed on your tv to make the bluetooth work. Since your tv is not a computer it cant be used in this way. If you want to hook up your laptop I suggest using the blue vga ports on both devices and a vga cable. You could also use hdmi if your laptop and tv support it.
Mar 31, 2011 | Toshiba Televison & Video
How do i set up bluetooth connectivity
If you have Windows XP with Service Pack 2 or 3 installed on the computer, then the computer has the Microsoft Bluetooth Protocol Stack. The Microsoft stack allows you to install an external Bluetooth adapter automatically. If the Bluetooth adapter supports the Microsoft stack but it does not install automatically, then you do not have the Microsoft stack on the computer.
>>Make sure that you have installed the HP All-in-One software on the computer.
>>Attach an HP Bluetooth adapter to the front USB port of the HP All-in-One.
>>If you are using an external Bluetooth adapter for the computer, make sure the computer is on and then attach the Bluetooth adapter to a USB port on the computer. If you have Windows XP with Service Pack 2 or 3 installed, the Bluetooth drivers are installed automatically. If you are prompted to select a Bluetooth profile, select HCRP.
On the Windows taskbar, click Start , and then click Printers and Faxes .
>>Double-click the Add Printer icon.
>>Click Next , and then select A Bluetooth Printer .
>>Follow the onscreen instructions to finish the installation.
>>Print as you would to any printer.
Regards
Riztech.
Mar 31, 2010 | HP Photosmart C6180 All-In-One InkJet...
Bluetooth keyboard and mouse stopped responding on Dell Dimension E520
try to insert another usb drive on the port.it the usb works then probably the bluetooth transmitter is faulty. If the USB drive also does not work... then probably the USB port of the computer damaged.
Jan 15, 2018 | Dell Wireless Keyboard Optical Mouse w0147
Plantronics 520 headset I want to be able to answer my home phone with the headset
Not sure if the '520' is a wireless headset for cell phones, or if it comes with a base transmitter unit and is made for desk phone. If it is designed for cell phone, then you have to have some sort of bluetooth transmitter for the PC phone (note that wireless is not the same as bluetooth). Check your computer store for small bluetooth adapter that plugs into USB port of computer.
Apr 15, 2009 | Gigabyte Computers & Internet
Cant connect to device through bluetooth or any other way!!
your problem isn't making much sense. you say you are using bluetooth devices to connect your pc to your printer and it isn't working because you need a passkey (encyption key).
Feb 21, 2007 | Belkin Bluetooth Access Point With USB...
Computers & Internet Logo
Top The Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Kelley Hopper
gbob59
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
