I have my camera and when I go to open it, it has Admin there. I can open it in internet explorer but it will not open.
    Top Expert:
  • Computers & ... Master
  • 30,511 Answers
Hello
I translated your question into English. Please Google
Make Model manual
for your mystery camera. Normally the storage volume is shown in Internet Explorer and shows the images. Or you can remove the SD card and put it in a reader.
Posted on Jan 14, 2020
6ya staff
SOURCE:
How do i log in to router's administration page?
you havnt given info about router
but best way to login on admin page to open iexplorer
type 192.168.1.1
user :admin
ps : admin
and login by default most routers take this ip
Dec 20, 2012 | Microsoft Internet Explorer 8
Tip
Solution for War Craft 3 behind Linksys routers.........
As the application requires certain ports to be opened on the router,try to follow the steps below to configure the router. Since you are connecting behind the router, you are going behind a NAT firewall.Therefore, you would need to allow ports for the remote access application to go through the firewall. You would need to know what port number application uses. You can check with the program manufacturer for the information, or see the Help menu.
For routers with old firmware versions (without the Cisco web interface):
1.Open Internet Explorer.
2.After "Internet Explorer" opens, please typehttp://192.168.1.1 into the "Address Bar" and click GO.
3.The "Enter Network Password" window will appear. Skip username and type admin (admin is the default password) as the password,and click OK.
4.You will need to click on the Advanced tab to the very right. Once the "Filters" area appears, please click on the Forwarding tab.
5.Once the "Forwarding" area appears, click the Port Triggering button. Once you've done this, a new window will appear.Enter the ports needed to be opened > Click Apply
For later firmware (that has the Cisco web interface)
4.Click on "Applications and Gaming" then click on the "Port Triggering" Sub tab. Enter the ports needed to be opened >Click Save Settings.
Example:
Customized Trigger Port Range Incoming Port Range
Application From ~ To From ~To
WARCRAFT 6112-6112 6112-6112
WARCRAFT 6113-6119 6113-6119
Hope this help everyone that has problem with the game.
on Jan 05, 2010 | Linksys Wireless-G Broadband Router
Tip
How to Upgrade Firmware of Linksys routers........
Example:
on Jan 05, 2010 | Linksys Wireless-G WRT54G Router
How do I find my network password
use www.portforward.com use the instructions set for port forwarding. to access your network under admin. its usually admin/admin. being username/password. or admin for password nothing for user. have to open internet explorer and type in ip address and it will take you to a screen to login as administrator.
FixYa Support
Aug 16, 2011 | Linksys WRT160N Wireless Router
Hello, I've followed the steps to set up my tv-ip100(w)-n trendnet camera, but when I open the setup, the camera can't be found to run the wizard. any ideas? I've tried turning off windows firewall,...
I need you to plug it back in using the Ethernet connection.
You will need to change the ip address on your lan adapter.
When you plug the Ethernet cable into your computer there should be two little computers that popup on the lower right hand corner of your screen. You need to right click the computers then select (STATUS), (PROPERTIES), (INTERNET PROTOCOL TCP/IP), (SELECT THE BUBBLE THAT SAYS (USE THE FOLLOWING IP ADDRESS). THEN TYPE THE FOLLOWING:
IP ADDRESS= 192.168.10.31 THEN HIT THE TAB KEY
THE SUBNET MASK SHOULD AUTO FILL.
THEN CLICK (OK) AND (OK AGAIN).
OPEN AN INTERNET EXPLORER BROWSER
TYPE 192.168.1.30 IN THE ADDRESS BAR AT THE TOP.
USERNAME: admin
PASSWORD: admin
That's it your in if you need help with the setup let me know.
When you have completed the setup of the camera you will need to go back into the network adapter setting and select the (OBTAIN ADDRESS AUTOMATICALLY BUBBLE) in order to get back on your local network.
Thanks,
Chad
Mar 21, 2011 | Trendnet Wireless Internet Surveillance...
Network password
Please go to Start - run -and type cmd then type ipconfig take the gateway and open the internet explorer and type the gateway in the addressbar in the internet explorer then type the username and password Admin admin. and take the networke password.
Sep 23, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Ssc21web password reset please! I tried HTTP and it asked for username and password. I tried root/root, root/admin admin/admin, etc. but nothing worked.
Samsung told me the newer versions of Windows and Internet Explorer, will not work with this system. Microsoft told Samsung it was their problem. Find a old computer with ME and Explorer 5 and it will work again. I have the ssc17web.
Oct 09, 2009 | Samsung SSC DVR Digital Video Recorder...
I dont remember my security key. How to change it?
You can simply open the router's Setup Page or Admin Page. Open Internet Explorer or any internet browser and on the address bar, type 192.168.2.1. It will ask you to type username and password, just type the router's username and password which is admin. Then look for Wireless tab, Wireless Security tab, you can change it from there.
Dec 18, 2008 | NetGear WGR614 Router
Dont know the password and user name
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
Nov 12, 2008 | D-Link AirPlus DI-524 Wireless Router
Modem settings for Siemens SL2_141
First of all check whether dsl yellow light is on or not.
if it is not on then contact bsnl local branch.
otherwise
remove dsl line from modem.
Then
type http://192.168.1.1
username= admin
password= admin
click WAN
edit pppoe 0_35_1
connection type=bridging
encapusulating =LLC/Snap-bridge
next
again next
save
save/reboot
close IExplorer
connect DSL line.
if its work plz reply me
[email protected]
Sep 14, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
Ekse
Marvin
Marvin
