Question about Panasonic Televison & Video
After the TV is turned on, is the power indicator on?
If you need tv parts you can link to https://www.abctay.com to search the tv parts number.
Posted on Oct 16, 2020
SOURCE: Panasonic TC-P58S1 won't come on,
Hi Volvo2001,
1 blink is an "unknown SOS" error code sensed by the processor upon self check. Most of this fault came from bad power supply and the caused was the leaky/dried filter electrolytic capacitor in that board. It will dropped the supply voltage and will disable the unit. Plasma TV is the most hardworking TV's nowadays and work in high temperature most especially the power supply board which causes the capacitor to fail after about 2-3 years.
Leaky capacitor has a physical indication of fault like bulged/dome at the top and can be easily be identified by visual inspections. See sample picture of electrolytic capacitor with bulged/dome at the top.
Dried capacitor has no physical indication of fault, you must have a capacitor checker to determine its condition or you may replaced all of them in the output stage. It will not cost you much since this parts is one of the cheapest parts in your unit (price depends on the capacitance and working voltage ratings that is printed on its body).
Click this "Sample Video" "Sample Video" for more info.
You may open the back cover of the unit and check this parts in the power supply board where the power cord is directly connected. Look also for bad solder joints(cracked/dried/cold solder).
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified tv technician or sent it in.
Also, check if your unit is still under warranty/extended warranty, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover because it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 27, 2011
SOURCE: What's your Panasonic TC-P55VT50 picture settings?
Click here to download the user manual to your TV. It have all details. Click here too to get more.
Posted on Sep 23, 2012
SOURCE: panasonic tc-p50g10 No picture/sound just a flashing light.
the flashing light is an error code count the falsh sequence and let me know how many times its blinking and I will assist
Posted on Sep 24, 2012
Jan 27, 2016 | Panasonic Televison & Video
Aug 30, 2015 | Panasonic Viera TC-P58S1 58 in. Plasma...
Oct 13, 2014 | Televison & Video
Nov 03, 2012 | Panasonic Viera TC-P58S1 58 in. Plasma...
Sep 04, 2012 | Panasonic Viera TC-P58S1 58 in. Plasma...
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily.
Aug 20, 2012 | Panasonic Viera TC-P58S1 58 in. Plasma...
May 21, 2011 | Panasonic Viera TC-P58S1 58 in. Plasma...
Aug 04, 2010 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
Jan 22, 2010 | Panasonic Viera TC-P58S1 58 in. Plasma...
Aug 19, 2009 | Panasonic TC-14KM30R 14" TV
Jan 01, 2021 | Panasonic Viera TH-50PZ800U Plasma TV
54 people viewed this question
