I only get the picture and no sound when I play my dvd player I think it is the tv because it works on my other tv.
Posted by Daniel Mead on
Harrie
    Top Expert:
  • Televison & ... Master
  • 6,746 Answers
Or the cable? or the connector, where you put in the cable (both sides)
Has this TV any sound, like white noise when nothing is connected? this could be a start to eliminate sources off the problem.
Did you switch off the sound? Mute. Or just very silent?
Posted on Jan 14, 2020
5 Related Answers
Service Dude
Jonathan Van Rensburg
  • 201 Answers
SOURCE: No sound when playing dvd or cd
  1. Check aux cables should be in Left and Right fornt speakers
  2. Check your dvd sound Settings under menu mka sure the downmix is stereo
Hope ths help
Posted on Jan 04, 2009
Anonymous
  • 3130 Answers
SOURCE: No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Posted on Aug 02, 2006
Anonymous
SOURCE: My Toshiba SD-3960 sound does not work.
My Toshiba DVD Player does not work. I can not watch online movies. What I ca do? Please send me if you have any suggestion.
Thank you.
Posted on Aug 30, 2008
Anonymous
SOURCE: no sound on TV
If the TV programs come's up with sound, then is possible that the TV set could be problem free. then cheek the system frequency if it need to be adjust from NTCS, PAL, AUTO MESECAM and so on. Cheek the DVD and VCR if they are in one of the following system settings and adjust the TV set to the settings at which the DVD or VCR is set to. Then you can also cheek if the cable is properly inserted, that is audio to audio and video to video. Nevertheless, if you have properlly connected your cables and set the system frequency to match with each other, and still no sound, then the TV could have sound problem.
Possible courses of sound failure in TV are as follows:-
1 RF stage
2 sound Ics or transistors
3 broken speakers
4 a break down resistor which supplie positive voltage to the sound curcult
Posted on Dec 10, 2008
Anonymous
  • 4 Answers
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Posted on Jan 28, 2009
Picture or sound will not come on while disc is playing
Think has other dvd players worked before on that tv. If so then has anything about the current dvd player changed such as the yellow red white cord? If so changing the old one back will help. The dvd player r/y/w jacks could be loose and the tv jacks could be loose as well which can cause a poor visual or no visual at all. If other dvd's work then its simply the dvd itself, make sure your not trying to play a blueray dvd in a regular dvd player they wont work in a normal player.
Feb 17, 2012 | RCA DRC247N DVD Player
My jensen dvd player mvb85
It still plays but no sound... probably the line going to the screen, but check the settings and try a CD that worked before....
Keep me posted...
Feb 06, 2008 | Jensen 8.5" Overhead DVD Player Package...
I am trying to connect a new Toshiba SDK 1000 dvd player to replace an older GoVideo that worked fine as a player but lost its ability to communicate with remote (bad sensor, I think). I get picture and...
Is the TV PAL or NTSC? The symptom you are experiencing is what would happen if you are trying to play back a NTSC signal on a PAL TV or vica versa. If you have a scart connection on theTV then use a scart lead to connect from the DVD player to the TV. Set the DVD player for RGB output which is independent of PAL & NTSC.
Feb 20, 2011 | Televison & Video
DN-V310 Audio no Picture
Don´t you put the progresive scan by mistake
Jul 08, 2009 | Denon DN-V310 DVD Player
I have sound but no picture
it does not support pictures
Jun 21, 2009 | Protron PD-007 DVD Player
DVD sound a problem but is playing ok.
try changing your dvd audio settings to stereo
Nov 12, 2008 | Toshiba SD-2800 DVD Player
DVD Player freezing
You need to take this back if you have the option. The picture freezing lets us know that the data stream is stopping. It will not work right again and it was just coincidental that you uses a diffrent kind of dvd.
Thanks
Josh
Sep 26, 2008 | TruTech PVS2119 19 in. LCD Television
How to set the telelvision to use a dvd,
On the remote ther is a tv/av button. Turn the DVD on and press play and the press that buttom on the tv remote and you will see your dvd playing. Have a good day.
Aug 04, 2008 | Philips Magnavox 27MS343S 27" TV
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
