Question about Sceptre Televison & Video
The sound works on my dvd player on other tvs but not on tne sceptre tv
Posted by Daniel Mead on
Harrie
    Top Expert:
  • Sceptre Master
  • 6,746 Answers
Then the TV is suspect, or the connector where the scart or HDMI cable is intering the TV. Or just the connector on the TV.
Posted on Jan 14, 2020
5 Related Answers
Anonymous
  • 1139 Answers
SOURCE: blue screen-tv doesnt recognize dvd player
Hello crawf and Saffyrre,
I have seen this issue before, and I have good news and bad news. The good news is the problem is caused by an electronic bypass circuit, The circuit is between the AV derived from the RF input connector (for cable TV and off air TV) and the AV derived from the DVD player Audio Video input jacks. Hence the problem of being able to plug the DVD into other TVs and it works. Now my question to each of you is; Does the TV work on off air and or Cable TV.
This might range from a cold solder joint on the circuit board, to a component actually going bad. I would suggest taking the set to a qualified TV repair shop and getting an estimate. If the cost is right have it repaired, if the cost is not right replace the TV with a new one.
If you do decide to replace the TV could you both send the bad TVs, so as I could figure out what is causing this problem, design a fix for it and then provide an actual online solution to this problem because this is happening way to much for it not to be a systemic problem with all of these Hello Kitty TV sets.
Thank you both,
I hope this helps,
Shuttle83
Posted on Nov 25, 2007
Anonymous
  • 232 Answers
SOURCE: dvd player hook up
DOES YOUR TV HAVE AUX RCA INPUTS OR JUST A STANDARD ANTENNA CONNECTION. CAN U ACCESS CHANNEL 3 OR 4 ON THE TV..HOW DO U ACCESS UR VIDEO INPUTS. A POSSIBLE SOLUTION IS TO GET A MULTI INPUT SIGNAL SELECTOR FROM RADIO SHACK THAT WILL TAKE THE RCA AND CONVERT TO STANDARD ANTENNA CONNECTION TO PLUG INTO THE PORT
Posted on Aug 04, 2008
dave1645
Dave Naylor
  • 834 Answers
SOURCE: Won't read DVD player
these unit are known for bad DVD deck
there is a place in Haverhill Ma that will fix it for you Tops Electronic service
Posted on Sep 20, 2009
gopakumarg43
  • 76466 Answers
SOURCE: Sceptre LCD--Input not functioning. Audio but no video when using inputs. TV antenna has video and audio.
Check the connecting cables for break. Check proper input selection.
Posted on Jun 05, 2012
bshldn
Loretta Northcutt
  • 736 Answers
SOURCE: What is the best dvd player for a sceptre 32 lcd hdtv
Yes, an hdmi connection is the very best. However, if you are not able to connect your dvd player the other way, just choosing hdmi or not might not solve your issue. Hdmi connections allow upconverting and thus a higher picture quality for you.
Posted on Dec 01, 2012
Need to hook up sayo sound bar to my elment tv and my dvd player together
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and cable box. ... More about : connecting soundbar dvd cable ... SolvedHow do I connectmy Element ELEFW392 TV to my Insignia NS-SB314 soundbar.
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... pretty hook them up and it works' followed by 'why did you buy a sound bar?' Do Ihave to connect sound bar to TV AND Dish receiver? and not to DVD? ... tv bluraysound bar and a DVR cable box together Forum; Solvedconnecting ...
Soundbar to tv [Solved] - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2198401/soundbar.html
Jan 11, 2016 | Televison & Video
How do I attach a combination VHS recorder/DVD player to my new Sceptre 19
The best way of connecting is an HDMI cable if both have this. If both have SCART then use a SCART cable. Using the RGB input is really old skool, you will need to use the TV controls to select that input because it won't select itself.
Dec 29, 2014 | Sceptre Televison & Video
Dec 01, 2012 | Sceptre X240BV-FHD LCD TV
I have a x32bv sceptre tv. everything works great but whn i plug a stereo into the audio out the audio buzzes.
What and where are you plugging into? Is sound normal on TV or when a DVD is played? This may narrow down what is happening.
May 25, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
We just got a brand new dvd/vcr combo and the dvd player works, but the vcr only plays the video and no sound. Have tried 5 different VHS tapes. DVD player works flawlessly.
How do u hooking up this thing,up by a AV component video RYW signal cable to an analog tv,a LCD,plasma tvs or an a HDMI cable to a LCD or a plasma tvs?More informations please?
Dec 11, 2010 | Magnavox DV225MG9 DVD Player VCR
I have a sceptre X46, the picture comes on but no audio
do a standard test. test other connections to see if the same thing happens. maybe it's your cable or your device. if you try other tvs and the same thing does not happen then it is the TV. If that's the case maybe you'll need to open up the TV to see what needs to be replaced. Usually these TVs come with 3-4 pcb boards. The one for sound is the one usually with all the connection plugs. maybe you'll need to replace that one.
Sep 07, 2010 | Sceptre Televison & Video
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
I cannot find the input button on the cyberhome dvd 300 have the white, blue, and yellow cable attached to tv from dvd.
I USED TNE SEARCH ENGINE TO FIND SET-UP INFO FOR A CYBERHOME DVD PLAYER. tHANK yOU FOR YOUR CONCER. -OZELENE
Apr 03, 2008 | Cyberhome Televison & Video
Televison & Video Logo
53 people viewed this question
Top Sceptre Televison & Video Experts
Dave Burton
Level 1 Expert
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
