I can not get sound on my dvd/vcr just the picture what do I do?
Posted by Daniel Mead on
2 Related Answers
freetek
Steve Allison
  • 5569 Answers
SOURCE: Vcr picture is scrambled on our VCR/DVD combo unit.
If you have used the VCR a good bit, the drum may need cleaning. VCRs derived their synchronization from the recorded tape and if the heads are contaminated, the sync signal may not be getting through often enough to stabilize the tracking.
This is not a fun thing to do but I once serviced these and it can be done with care and cure the problem.
You will need cotton swabs and (preferably) some pure alcohol (not rubbing alcohol). Gaining access to the drum requires removal of the housing and perhaps, in a combination unit even more, keeping mind that both of the decks works with astoundingly small signals; relatively low voltage signals and an amazing precision in the mechanisms.
If you can gain access to the drum, do NOT ever touch the shiny surface of it with fingers since the oil on the skin can really screw things up.
You can rotate the drum with a finger on the top of the drum and hold your alcohol wetted swab gently against it while rotating the drum.
If the drum is the cause of the problem, you should see some dark deposits build on the swab. If fibers catch in the opening for the heads, you will have to rotate it in the other direction while holding a tissue gently against the drum; no fibers from anything should remain snagged on the drum, otherwise your efforts will be for nought.
Good luck-
Posted on Sep 13, 2009
SOURCE: I have a Sony DVD/VCR player. I can't get a
clean the vcr heads they are dirty
Posted on Sep 05, 2010
Toshiba modelsd v392su dvd sound and picure perfect vcr SOUND GREAT NO PICTURE and I have done all that is needed to review all inputs to make sure thye are in and i know they are in the proper...
DVD produces a great picture with sound - but the VCR is not producing a picture? is it snowy? or a black screen? if it is a black screen, the video output from the VCR is possibly faulty, this is not economical to repair. If it is just snow, and there is slight evidence of a playback picture from your tapes, try cleaning the video heads with a head cleaning cassette (available from eBay and electronics stores as a discontinued stock item).
Since Hi-Fi VCRs have the left and right stereo track on their head drums, and this drum becomes worn or dirty, the sound deteriorates along with the picture - mono sound usually with lots of snow.
This is a combo unit - it has a VCR/DVD common output section on the rear - allowing DVD and VCR pictures to be viewed when the respective drive is selected. When you checked your input connection, did you check the rear of the unit? you may have connected 'DVD priority out' instead of the VCR/DVD common out. If you did connect the common out, and still have no VCR picture, try the head cleaning suggestion as above. If that fails, consider replacing the unit as a last resort.
I am offering this suggestion 'gratis' - free of charge.
Apr 10, 2011 | Toshiba SD-V392 DVD Player/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
I can see the picture but can not hear sound. All
try changing the down mix in the sound settings on your dvd/vcr combo
Jun 07, 2009 | Zenith XBV442 DVD Player/VCR
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
No video in VCR mode
Could be dirty video heads. Try a cleaner....accordianman....
Jan 15, 2008 | Sanyo DVW-7200 DVD/VCR
DVD sound but no picture...after pushing progressive scan button
desactivate the progressive scan or if u don't know how to do it, just do a reset on the dvd player.
Dec 29, 2007 | Samsung DVD-V4600 DVD Player/VCR
No picture
Sounds really broken. Unless you can find a replacement DVD drive for low money , you may have to junk it.
Dec 12, 2007 | Sanyo DVW-7000 DVD Player/VCR
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
