SOURCE: Push Power button, green light goes on for a few seconds then nothing....
I would suggest taking a look at the power module if that can be replaced. The Fuse blowing may have only been the beginning of the problem. Any recent issues with under or over voltage in your home?
Posted on Jan 22, 2007
SOURCE: Hi, my Playstation 3 does not seem to work,
Sadly there isn't much the average user can do to fix this problem.
It's
hardware related.
You can try powering on the system with the hard drive removed,
but it's VERY rare that will solve your problem.
Check out this
guide here and this one here.
Those are DIY guides but
if you're not up for the challenge I would
highly recommend getting the machine fixed direct through Sony.
You can
contact them @ 1-800-345-SONY.
They charge a flat 150 rate for
all repairs.
Best of luck!
Posted on May 21, 2010
SOURCE: Viewsonic VG2230WM....I have replaced both
You have one of two things wrong. One the new power supply board may be bad, we have seen quite a few power supply boards purchased on Ebay that are just as bad as the ones people are trying to replace. They send them to us for repair along with the original board and both have bad capacitors installed. Many of these boards are coming in from PC recyclers that are just striping monitors for parts and not rebuilding the boards before the sell them. Check the tops of the capacitors for bulges if you find any them the board is bad.
If the board is in fact good then the cause is bad florescent back light bulbs in the display panel. When the fail they pull to much current trying to light up and this trips the over current circuit in the power supply board which shuts the power supply down to prevent damage and this turns off the display. The bulbs can be d but this will be a very involved project. You can do a Google search for instruction on this process but keep in mind this bulbs are very fragile and thin, easy to break.
I hope this helps. If you have any questions just reply to this answer.
BuddyMc
Posted on Aug 22, 2011
Dec 06, 2017 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
May 30, 2012 | Philips 42PFL7432D 42 in. LCD Television
Aug 22, 2011 | ViewSonic VG2230WM LCD Monitor
Sep 11, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Jun 07, 2010 | Toshiba 56HM66 56" Projection HDTV
Sep 07, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Jul 09, 2009 | E-Machines eMachines Desktop PC
Jul 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Sep 02, 2007 | Toshiba 46H83 46" Rear Projection...
Jan 20, 2007 | Mitsubishi VS-60601 60" Rear Projection...
