SOURCE: Sharp AL1642CS makes clicking sound when rollers turning
I had the same problem. Took apart, cleaned, and lubed the fuser unit. Problem went away.
Posted on Feb 02, 2010
SOURCE: I have a Lamiart-3201 laminator
Make sure your laminator is heated up properly before feeding material through. Usually, for a low-end laminator, you will wait anywhere between 10 to 20 minutes before it is completely heated up, allowing you to use it. There should be a red button that will tell you it is NOT ready yet, and a green button will tell you it is.
Posted on Nov 16, 2010
SOURCE: my new TL901 just stopped working.
It is probable the heating element burned out. The heating element is just a long tubulat incandescent lamp.
You could try returning it to the store and exchanging it for another one. Otherwise in the documentation there is a contact information page, probably the phone number would be the best, and work with them that way should you get any issues from the store.
Posted on Dec 22, 2011
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull
it up and to the left, only then you would be able to take pink rollers
and metal piece away. Step by step do this (BTW, make pictures of each
step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench.
Then both parts (14) from both sides [4 in total]. Then both parts (2).
Then take out screws that are holding this vertical plastic wall place.
There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical
plastic wall on the left side of laminator. If not, try loosing some
screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
SOURCE: Engraved / carved markings or scratch in laminating roller
probably will be best to junk it and get another one as the cost to repair will probably exceed the new cost.
Posted on Jul 06, 2014
Apr 16, 2015 | Office Equipment & Supplies
Mar 13, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Sep 09, 2014 | Gbc Heat Seal Ultima 65 Laminator 1710740
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
Nov 23, 2013 | Fellowes Saturn 2 A3 Laminator Laminators
Sep 30, 2013 | Office Equipment & Supplies
Jan 05, 2013 | Nordic Track Nordictrack Track C3000...
Dec 22, 2011 | Scotch 9" Tl901 Hot Laminating Machine /...
Nov 17, 2009 | Icon Epic T60 Treadmill
66 people viewed this question
