Question about Toshiba Televison & Video
Toshiba 43 inch fire tv edition stuck on boot screen
Posted by Aaron Sanchez on
marycalantha
  • 4 Answers
I also find out about this, hoping to find the best answer slope game
Posted on Jan 14, 2020
4 Related Answers
Anonymous
  • 4402 Answers
SOURCE: 43 inch rear projection
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 22, 2008
Anonymous
  • 5 Answers
SOURCE: my tv is stuck on channel 43
You may have accidentally pressed 'Favorite' on the remote. Try pressing 'Favorite' to unlock the controls.
Posted on Aug 22, 2010
eagle338
eagle338
  • 4889 Answers
SOURCE: i have a toshiba rear
The black box you are seeing is because closed caption is enabled. Turn it off and the box will disappear.
Posted on Nov 02, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: can't connect to xbox 360 with 43 inch toshiba rear projecton tv
are you trying to connect via one of the two so called color stream inputs or what?
Posted on Aug 28, 2012
I have a Toshiba 43 inch projection TV. Six months ago the convergance function was repaired by a TV repairman. Now the TV is periodically turning on and off by itself while we are watching it. What...
More than likely, as the tuning is governed by a remote control function, it is a dodgy remote control.
Try putting the remote control out of the room.
Hope this helps.
Oct 31, 2010 | Toshiba 43HX71 43" Rear Projection...
Toshiba 43a10 has an intermitent blue screen
it must be because ur tv is not being serviced regularly
cos the chips get fungus growing on it it happened to my
tv too its is 55" toshiba rear projection so get it to an toshiba repair centre.
Aug 13, 2009 | Toshiba 43A10 43" Rear Projection...
Toshiba projection tv
Sounds like it blew an "Internal Fuse"
if you want to fix it..simply open rear of TV and look for the fuse.
here is link for a manual if you do not have one.
Mastersage
http://www.devicemanuals.com/guide/Television/Toshiba/Toshiba-43H70-User's-Guide-TVRNME9EUT.html
Feb 05, 2009 | Toshiba 43H70 43" Rear Projection...
Toshiba 43" Rear Projection tv (Just show's Blue Screen)
Hi Chris,
It sounds like you have a tuner problem. Usally the set will turn blue if there is no signal to the set, which is first generated from the tuner. It could also be the processor on the main board, but I would look at the tuner first.
Good luck and I hope this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
May 28, 2008 | Toshiba 43H70 43" Rear Projection...
Apex 43 inch tv
Convergence is when you aim all three of the projectors, your tv has three, so that the images they produce all line up with each other. This usually doesn't generate a white line across the middle of the screen though, there is a button on the front panel of your set that automatically converges the three projectors, you can try using that.
Nov 06, 2007 | Apex Digital GB4308 43" Rear Projection...
My tv is stuck on channel 43
Jul 24, 2007 | iLO 3200 32 in. LCD Television
Toshiba 43 inch projection set
Possible bad solder connections in convergence circuit or vertical deflection circuit. This happens in alot of equipment. After warm up, expansion of joint pulls connections loose. Recommend not running like this, could cause component failure.
Dec 22, 2006 | Toshiba 57H83 57" Rear Projection HDTV
Nov 22, 2006 | Toshiba 53H71 53 in. Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
