Question about Car Audio & Video
2012. Why is radio intermittent?
Time and station display stays on
Posted by leroy moses on
5 Related Answers
emissionwiz
Marvin
  • 85239 Answers
SOURCE: 1999 Cougar radio display works sometimes
the radio display is lighted from the back by a miniature bulb, this is the problem, the filament is almost burned out or the bulb is loose in the socket, to replace this bulb u must remove the radio (requires special radio removal tool kit, about $6.00) and then the top cover off the radio, the bulb socket twists into the back of the display, you can buy the bulb at any parts store for about $2.00
Posted on Jun 16, 2009
mrwiebe28
  • 19 Answers
SOURCE: check engine light stays on - 2006 Dodge Ram 2500 Cummins
Go to Autozone, they will check your engine codes for free.
Posted on Sep 23, 2009
Puppet03
Puppet03
  • 172 Answers
SOURCE: MY DODGE 98 2500 TRUCK TRANS WILL NOT LOCK UP 1 OR
Did you check the E-brake ? if not that take a look at the brakes ...transmission
Posted on Oct 25, 2009
Marcel Michaud
  • 175 Answers
SOURCE: I accidently did something the
continually press/release the center of the tuning know until you have the preferred display you want and then press and hold the same button until the system beeps (1-2 seconds). It will now save your preferred default screen (clock in your case)
Posted on Apr 04, 2011
SOURCE: dodge 2500 diesel wont start
This one is easy. When you remove the filter for service and are ready to install the new filter, fill the filter with transmission fluid. Yes, you read that right, transmission fluid. I am an ASE certified master technician, this will stop the air bubbles that are introduced into the fuel system, and causing the fuel system to lose it's prime.
Since the air is already introduced into your system, on the side of the engine (driver's mostly on the same area of the filter) there is a rubber boot covering a PRIMING button. DO NOT ATTEMPT TO START YOUR TRUCK AT THIS TIME!!! DIESEL FUEL IS UNDER EXTREME PRESSURE WHICH CAN CAUSE SERIOUS INJURIES!!! PLEASE, pay attention to this warning!! crack the seal on the filter open, remove the filter, fill the filter with transmission fluid, re-install the filter, and then prepare yourself to push that rubber button for some time, perhaps as long as five to ten minutes. When the button gets extremely hard to push, the system should be primed. Remove all tools and your hands from area, and attempt to start the engine. If it doesn't start, go back to the rubber button, and reprime the fuel system. Sometimes the process may take as many as ten attempts before it starts.
Hope it helps!
Warmest regards,
Elwin
Posted on May 20, 2012
I have a 2007 Subaru Tribeca. I preset the AM radio stations and when I restart my car the next day, it is on FM2 and all the AM stations that were programmed are gone. Anyone had this problem?
2007 Outback Wagon - radio controls freeze - Subaru Outback ...
www.subaruoutback.org > ... > Audio, Video, Security, & Navigation
Mar 22, 2012 - Have a 2007 Outbak Wagon with radio controls that freeze for no reason. It freezes and fixes itself randomly. What I mean by freeze is: can't ... Any luck fixing poor radio reception? - Subaru Outback - Subaru ...
Jul 19, 2010
08 O.B. radio/hvac control lighting prob.
Jun 30, 2010
radio is on, but no sound through speakers
Apr 21, 2010
Radio & Climate Control Display - Subaru Outback
May 25, 2009
More results from www.subaruoutback.org
Subaru radio problems 2008 outback - YouTube
? 0:09
https://www.youtube.com/watch?v=N9W78_ZlBdc
Oct 29, 2012 - Uploaded by NRHTX
Subaru radio problems 2008 outback. NRHTX ... Up next. 2007 Subaru Outback Suspension Noise Repair -EricTheCarGuy - Duration: 23:04.
Subaru Legacy GT Radio Problem - YouTube
1helpful
Touch screen dvd locks in on back up camera
You have a short somewhere try unhooking the power to the player then see if your issue continues
Chrysler 300 radio cannot pre-set tuned stations
If radio has save button then tune your station push save button then push a number on preset you want it saved to. The radio automatticlly stores the strongest station in your area.
My clock on my 2008 impala doesn't stay on display the radio station does,how do I get the time to display all time?
I've looked through the manual and don't think you can have it to stay on the clock. If you want to have a look you can download it here. https://www.chevrolet.com/content/dam/Chevrolet/northamerica/usa/nscwebsite/en/Home/Ownership/Manuals_and_Videos/02_pdf/2009_chevrolet_impala_owners.pdf
My radio goes out from time to time. all the lights on the small knobs (bass,treble, etc.) blink and display reads EEEE instead of the time or a radio station. The radio does not work when this happens and...
sorry to say yes its the radio other than remove it and unplug the connectors it will continue to drain your battery, the memory curcuit shorted out inside the radio,thats the part that keeps the stations memorized when the key is off,
1helpful
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
3helpful
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
2helpful
I have a problem with time display on my Bose CD/Clock Radio.
I found the answer on the Bose website in the manual for the radio. While the radio is on, hold down Alarm Setup and preset 1 at the same time. That will set it so the clock displays. If you do the same thing but hold down preset button 2, that will display the radio info all the time.
Radio
THIS IS NOT SOMETHING YOU CAN FIX IT IS A SMALL CIRCUIT BOARD INSIDE THE RADIO THAT RUNS THE DISPLAY AND BUTTONS FOR STATION CHANGE ETC. THE ONLY WAY TO FIX IT IS TO PULL THE RADIO OUT AND SEND IT TO A AUTHORIZED GM/STAURN ELECTRONICS REPAIR CENTER, THEY ARE THE ONLY ONES THAT HAVE THE PARTS AND REPAIR MANUALS.
AM/FM receiver
the problem is in your tuner for me it is betwen the IC and the IF transformer. if u cant fix it buy new stereo componet.
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
 Francisco Mauricio...
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
