Question about Universal Televison & Video
I have a pros can tv and there is no buttons on it and I have no remote I have bought 2 different universal remotes and neither one of them will link to the tv what do I do?
Posted by Joanna Schaffer on
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: No sound
Hi, It seems that the SAP, no audio, distorted audio is a common problem for some RCA units even with the use of the original remote and in your case made more difficult with a replacement remote. Two things you can try: 1. Some say that unplugging the TV set for a long time, a couple of hours at least will do a hard/system reset on the microcontroller inside the TV hopefully resetting set-up the audio (including SAP) to default; 2. contact Customer Support at Thomson and explain your problem; 3. Try going a google on "RCA SAP manual reset"; or 4. Buy an original remote and not another replacement. Hope this work out for you and give you some ideas. Pls post again how things turn up. Good luck and kind regards.
Posted on Aug 06, 2007
moose69247
  • 75 Answers
SOURCE: akai 32" LCD TV/DVD Combo- universal remote
i have the same tv i bought a rf10 universal remote at circut it works fine
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_87482045335a4757
Posted on Feb 13, 2008
Anonymous
SOURCE: Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Posted on Jan 16, 2009
Anonymous
SOURCE: cant get universal remote to work with broksonic tv
Code 0115 worked for me on the Phillips PM335 remote FINALLY!!!!!!!!!!
Posted on Jul 01, 2009
SOURCE: TCL 21K77 Problem with TV/AV without Remote Control
hi!! my promble is my tv tcl cannot press the button and cannot press remote.my remote is work to another tv tcl brand. and automatic on and off after 10min or 15.
Posted on May 19, 2013
My remote control broke, and I bought 2 different universal remotes that will not operate the tv.Do you know why? The model number is PLDED3273A-B
You should set it up with the set-up code to your TV brand; with the codes said to it in the code list of the remote control. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 22, 2014 | Proscan Televison & Video
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
No idea how to use new universal remote
Turn on the TV,press and hold the CODE SEARCH button until the remote lights up,press TV button,the light will blink and stay on,enter the code,the light will go off, press the POWER button, the TV should go off, if not, repeat the steps using a different code until you get one that works the TV. ..hope this helps..
Mar 29, 2010 | Innovage Jumbo Remote Control
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Universal remote
Universal remotes never work good anyway. You will need the original remote anyway to work the different functions for the TV.
The cheapest that I can find one for you is at NewRemoteControl.com, it's $32.95
Here is the link for you:
SYLVANIA LC370SS8 LCD TV REMOTE CONTROL
Mar 24, 2009 | Sylvania LC370SS8 Television
I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Oct 17, 2008 | RCA Universal Remote Control
Need Remote for AVOL t.v
go to www.AVL21c.com this is the company that makes the AVL Brand televisions for AAFES
Aug 17, 2008 | Sony RMT-V202 Remote Control
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Televison & Video Logo
37 people viewed this question
Top Universal Televison & Video Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
