SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Posted on Nov 23, 2007
SOURCE: How to replace the ibt belt or where to buy ibt belt assamble
I have got the new one it cost about $400 usd i you want i show you how to change. Greetings
Posted on May 17, 2009
SOURCE: Phaser 7760 - RAM ERROR
yes often your printer Ram or reset then solve it
Posted on Jun 26, 2009
SOURCE: Xerox Phaser 7760 Prints White Lines Diagonally Across Page
That is normally caused by a bad developer housing.
Posted on Jul 16, 2009
SOURCE: how to change ibt belt
The error code 004-346 is an IBT home position sensor. The belt may be damaged or didn't move.
The sensor which is mounted on the frame looks at the belt to see if it made a full rotation. Perhaps the sensor is dirty or damaged. Maybe the home reflective mark is damaged.
The belt may be damaged or shredded. Find out why the old belt was damaged before you install another part!
You probably need to purchase a new IBT belt PN 802K208991. The Xerox technician has a proprietary laptop to clear the codes and calibrate the "Belt Edge." The belt is very fragile, so whoever installs it needs to be very mehtodical and careful.
These may preclude you from repairing that yourself.
Whit
Item, Inc.
Posted on Dec 02, 2010
Mar 26, 2015 | Xerox Phaser 7760 Laser Printer
May 12, 2014 | Xerox Phaser 7760/YDX Laser Printer
Mar 23, 2014 | Xerox Phaser 7760 Laser Printer
Feb 16, 2014 | Xerox Phaser 7760DN Laser Printer
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Nov 16, 2010 | Xerox Phaser 7760/YDX Laser Printer
Jan 13, 2010 | Xerox Phaser 7760 Laser Printer
Oct 13, 2009 | Xerox Phaser 7300DN Laser Printer
Aug 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
60 people viewed this question
