Question about Toshiba Televison & Video
I have a toshiba tv srswow hd ready. The sound goes on and off rapidly in time with the mute signal. P!eaze help
5 Suggested Answers
dewan nafees ahmed
  • 1894 Answers
SOURCE: Illegal Signal DVI/RB 3
see this link...here is the user manual....
Posted on Mar 01, 2008
Jonathan Wolf
  • 46 Answers
SOURCE: No HDMI input socket on Toshiba 'HD Ready' TV
There is an easy way to adapt the cable.
Any good computer shop will have the adaptor.
Take the HDMI cable to them, and tell them you want an adaptor to go to composite signal.
(I know that they're made, many of the graphics cards I use to build computers come with that cable adaptor)
You also might try Best Buy or Radio Shack, but you might not have much luck with them.
Posted on Jan 16, 2009
Anonymous
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Posted on Feb 17, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: dose my tv (Hisense TL3000) is hd-tv ready
Not all units were fitted with the DTV tuner before the switch over occurred. you set should have an insignia that sates that it is DTV ready. if this insignia is not on the box or actual set, you will need a converter box to receive this DTV signal.
Posted on Jun 21, 2009
fieldy14
Adam Jerome_lagudi
  • 456 Answers
SOURCE: no video signal on hd tv by toshiba. could it be
check that you are getting signal from the dvd player by using another tv, if it works the dvd player is fine(which u have determined anyway) also check the input on tv to ensure that the input ccty (circuitry) is working as well. if the dvd player is working and tv signal is being picked up, check all the plugs and cords. Good luck.
Posted on Nov 16, 2009
Westinghouse problems
it could be the signal or the cables try connecting a working dvd player into another input and chec operations..
Aug 01, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
I have been watching my LG 42LD520 for 2 months. Today turned it on and there is no sound. Any ideas??
If you are using a satelite system...just unplug the satelite receiver for 30 seconds and plug back up. Try unpluging the TV and check for the mute function...it may be off. Also go to the sound menu in the TV and be sure the speakers are on. The worst problem is a main signal board.
May 28, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
Is this model HD ready?
Yes,this tv is able to play HD signal,but must have pay cable or satellite signal hook it up to it.This tv is CRT-(tube tv) analog design tv,antena alone will not work without a converter box.
Feb 17, 2011 | Toshiba 50A50 50" Rear Projection...
It is digital (HD), I don't need converter?
If your set is labeled as "HD ready" then it will accept HD signals from, for example, an external HD tuner or other source. The set can be HD Ready, as is my Samsung TV, but my set has only the older NTSC type tuner. I therefore use a digital stream HD tuner which works great to receive over the air signals. Also digital does not mean a set is HD. There are sets that are standard definition digital sets that can receive digital signals, but do not produce HD. If you are using cable, in most cases, you can continue receiving your cable as usual.
Nov 25, 2009 | Toshiba 36A40 36" TV
Sound doesn't work on Toshiba 36"
Unplugged the TV for 5 minutes and the audio is working now . . . what a pain to have to do this with how complicated theater systems are today!
Sep 02, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
No sound
On your remote you should have a mute button. Or some will cancel mute when you press volume up or down. Make sure you are using the TV remote and not the cable or dish remote.
Jul 18, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Toshiba 42hp93
Press the MUTE button twice on the remote control, then press and hold the MUTE button, while pressing the MUTE button press the MENU button on the TV at the same time. This should get you into the service mode Good luck and be careful.
Oct 26, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Sound
This is probably due to improper signal..activate the sound stable feature on your tv to set the sound output to required range no matter what the strength of the signal is..
Oct 18, 2007 | Toshiba 65HDX82 65" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
