SOURCE: movado watch
Find the decent watchmaker near you and ask for the new glass as mineral and sapphire glasses are not possible to polish due to the exeptional hardness.
Watch will instantly look much better and water resistance will not be affected.
SOURCE: Changed battery in Movado. Is there a way to reset?
No, there isn't any buttons you are missing.
My first advie is to test battery for full power. If it is, then clean all contacts in battery hatch.
If it still do not work, the gear train can be jammed or the integrated circuit faulty and repairs can be undertaken by skilled watchmaker only.
SOURCE: Does the movado watch have battery?
unless its a watch u have to wind, which i doubt it is, then u need to test the battery
SOURCE: my watch battery low
mcdevito75 here, Movado a FINE watch, BEST BET, look for a small watch repair shop in your area to change the battery, Movado watches have a very good over all value and any damage can lessen that value, not to mention the jewelers screwdriver you"ll need to change that battery.
SOURCE: I am a Jeweler and
mcdevito75 here, You don"t really have to be an authorized Movado dealer or repair center to service Movado watches, specially if Movado doesn"t have a warrantee on that particular watch. Also you say the stem was hard to turn, sounds like this particular Movado watch mechanism was starting to fail. The long and short is, you replaced the battery, set the watch and all was well when the customer recieved the watch back also, a Quartz mechanism could give out at anytime, just as a light bulb can. Have the customer come back with the watch if possible, place a drop of oil on the stem, try a replacement battery. Always ley your customers know what you find, and get a history of the watch from the customer before work, Age of watch, how it"s worn and stored etc. this way your covering yourself for any watch liability. You can offer this customer the mentioned re- service or a refund just to keep the customer happy.
