Question about Kohler Electrical Supplies
I have a kohler 6.5 ESZ marine generator with under 200 hours . Had a couple shops check rotor and stator for shorts.....even shipped to CA .....all checked good .
Posted by nick scivally on
  • Carl Rock
    Carl Rock Jan 13, 2020
    Describe problem?
sherlywang
    Master:
  • 425 Answers
Diesel generator set: www.dieselgeneratortech.com
Posted on Jan 15, 2020
5 Related Answers
arealplumber
Better Plumbing
  • 33 Answers
SOURCE: Schematic
I looked for several minutes and this is what I found:
Kohler 13EOZD wiring diagram
I went to the Kohler site, entered the number and it cross referenced to the above number. The wiring diagram is on page 90.
Hope this helps!
Posted on Dec 05, 2008
mamicheddy
mamicheddy
  • 79 Answers
SOURCE: Hello, I have a Kohler Marine Generator that says OC on the menu when I try to start it. Any ideas?
OC stands for Over Crank. How long does it take before the genset starts?
Posted on May 07, 2009
Anonymous
  • 225 Answers
SOURCE: Same Problem, diodes fell out of bridge rectifier assembly
pulling to many amps,diodes could not handle amps so they failed.unit should have kicked its breaker before the diodes burned out.most units have their own breaker to protect the system.I would replace the control board first see how unit reacts,probly fine,if not the you go to next step.
Posted on Jun 27, 2009
Anonymous
SOURCE: I have a honda generator em2500x voltage problem
Cummins P2200, 2KWatt, it starts fine, but after a couple of minutes, it gives quite high voltage output, meter needle goes beyond 300v, engine speed seems high since throttle is increased, indicator light on generator also becomes bright, after a minute or so, things come to normal, sometimes takes few minutes to come to normal, situation is same, with/without output load. this happens within initial 15 minutes after startup, afterward everything is normal.
Posted on Aug 14, 2009
Sheldon Dedek
  • 909 Answers
SOURCE: Coleman Generator not Making Power
actually, it sounds like the diodes are blown. Check our diodes.
As for checking stator, find the two wires, typically labeled L1 and L2 that are going to it. Measure with a multimeter. If there is no visual signs of damage, continuity can indicate a good stator. You should not have continuity between either wire and the stator frame.
The same goes for the rotor as well. The resistance measurements will not be the same for each one though.
Unfortunately, Powermate is out of business, and service information is scarce.
Posted on Aug 25, 2009
I have a Kohler Confidant 5, model 5ckm61 generator in my RV, serial # 338225, spec# 101218. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depressed ....
The control board needs to sense a voltage coming of stator windings to complete the run circuit or else it will shut down. Check the stator and rotor windings for resistance and shorts
Oct 21, 2013 | Electrical Supplies
I have a 7.5r27 kohler marine generator has less than 100 hours on total rebuild on motor and upgrade on generator electronics all work done by Nixon Power,Nashville Tn. It ran and worked fine,then it...
Given the work you have done, you never mentioned if you have had the stator and rotor tested? if you can get it running check for DC power on the brushes. that will help isolate. If power blinks for a second, that is the control trying to flash the rotor, if the rotor has a short the controls will remove the excitation voltage. Check that before going to any major expense
Sep 14, 2013 | Kohler Electrical Supplies
Kohler 10 runs only while holding start
Oil pressure, or no AC output from the stator, check stator and rotor for resisitances and shorts.
Nov 18, 2012 | Kohler Electrical Supplies
Kohler generator wont stay on
Check the oil pressure switch, and oil level first. Then check rotor brushes and rotor slip rings may need polishing. If the problem is still there check stator and rotor windings
Aug 25, 2012 | Kohler Electrical Supplies
Generator starts then shuts off in 8 to 10 seconds it shuts down
Check oil, and sensor, rotor rings, and brushes, then stator rotor for shorts
Aug 18, 2012 | Kohler Electrical Supplies
Under voltage
Check rotor slip rings,brushes then rotor and stator for shorts
Aug 08, 2012 | Kohler 17 kW Emergency Power System -...
Kholer power systems generators 18RESL auto shut down code UU
UU is generator under voltage. Check to see if it does it without laod also. if it does you will need a pro to check and ohm the rotor and stator for shorts
Jul 11, 2012 | Kohler Electrical Supplies
Kohler marine generator troubleshooting
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
May 02, 2012 | Electrical Supplies
Electrical Supplies Logo
95 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
