Question about Vision Televison & Video
I work with control Multistar Vision 24x7 Dvr" but the mouse didnt conected to dvr ? How can i do ?
Posted by Seed on
Attique-ur-Rehman
    Top Expert:
  • Vision Master
  • 2,677 Answers
Https://www.youtube.com/watch?v=r5D_0se5rz0
Posted on Apr 21, 2020
3 Related Answers
Anonymous
SOURCE: vizio and the directv dvr
Vizio recommends using code 11758 or 10178 for Cable/Satellite universal remotes that use five digits such as DirecTV. For four digit Cable/Satellite universal remotes , use 1758 or 0178. For three digit Cable/Satellite universal remotes, such as Dish or Echostar, use 627. These codes typically make the Power, Volume and Mute functions work.
Posted on Feb 01, 2009
Anonymous
SOURCE: archos dvr station remote control
It sounds simple, but the archos must be facing the sky+ box. I spent hours messing around with archos support and qvc and in the end it was simple. I put the archos 6" away from the sky+ box, facing it, selected thomson, in the loist of sat receivers and it was code 15 of 16, good luck.
Adrian
Posted on Feb 11, 2009
Anonymous
  • 5 Answers
SOURCE: DISH DVR doesn't respond to remote
  1. If this is a TV2 location take the remote to the location of the DVR.
  2. Open the door on the right side of your receiver.
  3. Press SYS INFO.
  4. Press Record multiple times on your remote.
  5. Exit the screen and see if the remote works, if not replace the batteries and repeat steps 1-4
  6. If the remote still doesnt work, and this is a tv2 location (no receiver in the room with the tv) check the antenna on the back of your receiver, make sure that it is connected tightly and standing straight up.
  7. If none of this works call Dish and ask for a new remote.
Posted on Jan 31, 2010
How can i joint the dvr with computer by the network cable
You cannot connect the two directly. The IP address can be found in the setup page of the DVR, You then type that address into your browser to get into the DVR. The DVR must be connected to the internet using a port on the router.
Mar 30, 2018 | Televison & Video
Tip
DISH Solo DVR VIP612 Program TV VCR Remote Code
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | DISH Network ViP 612
MOUSE NOT DETECTED ON HIKVISION DVR DS-7204HWI-E1
Have you tried another brand and type of mouse on the DVR? Not all DVR's are compatible with all mice.
Feb 28, 2018 | The Computers & Internet
I have Lh126000 lorex dvr. After upgrade can't login in to dvr how to restore dvr without login
u need to conect it to internet. login signals canot pass thru walls
Sep 08, 2016 | Lorex Home Security
How to set sunluxy dvr to factory setting
remove the outer cover of the DVR try to find the on board battery
remove it for about 5 sec or 10 sec (while power off)
Jun 25, 2014 | Lorex SG6153 / Weather Resistant Mini...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
When i reboot my Zmodo dvr I Can't get menu to come up or mouse to work HDD light keeps flashing,blinking hdd light,HDD indicator light
I had the same problem. Did their online tech support and Patty told me to hold down the "rewind" button on the DVR for 20 secs. You should now be able to right click your mouse to access the on screen menu. You will now want to go under system, and a/v setup and change the device to VGA instead of Vout. Now you can reboot and not have to go thru holding down the buttons anymore. Worked for me.
Oct 02, 2012 | ECHO1USA Zmodo 4 Ch Complete Dvr Kit -...
How do iI hardware reset factory Multistar dvr h264 beacuse I forgute admin pass.
I forgate my multistar dvr password plz give me any solution
Jan 19, 2011 | Cameras
Televison & Video Logo
59 people viewed this question
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
