Question about Exercise & Fitness
I have a Medicarn inversion therapy table Pro 2. The rubber on the arms is starting to perish. Where can I get replacements? I am based in the UK.
Posted by Mike Bass on
ray gallant
    Top Expert:
  • Exercise & F... Master
  • 73,506 Answers
CHECK WITH THE PLACE YOU GOT IT
Posted on Sep 20, 2021
4 Related Answers
Anonymous
  • 1226 Answers
SOURCE: broken drive rubber band
buy a rubber band at the market
Posted on Jan 07, 2008
Anonymous
  • 1478 Answers
SOURCE: concetina flusher perished - rubber pusher to
I will advice you replace the rubber pusher to fix the problem, you can get the rubber pusher at stores or you check ebay.com for it
Take care.
Posted on Oct 20, 2010
sylviaivie
  • 1564 Answers
SOURCE: bobbin tire perished
http://www.sewingpartsonline.com/brother-sewing-machine-parts-model-list.aspx
Posted on Nov 06, 2012
Michael Lawing
  • 545 Answers
SOURCE: replace speakers on imac G3 M5521
ifixit.com has wonderful guides. You'll have to take apart the entire case to get to them. Parts should be relatively cheap too, since the machine is so old.
Posted on Dec 12, 2012
What's the inverse function of f(x)=-x
I get f(x) = -x as the inverse of f(x) = -x.
I set up some tables to see if this is correct.
x ' y
-2 2
-1 1
0 0
1 -1
2 -2
For the inverse function, we should be able to put in y and get back x x ' y
2 -2
1 -1
0 0
-1 1
-2 2
The equation of this function is f(x) = -x.
Good luck.
Paul
Inverse Functions
I practice a few different types of massage therapies. How do I know which massage table is best to buy?
It's not practical to buy a different table for each different therapy especially as with the right planning, you can buy a table that works in many different settings. Read this article which gives a detailed buyers guide for different therapies. http://www.bestmassage.com/Massage-Table-Buyers-Guide
Aug 14, 2012 • Furniture
My pro 2096 has no volume
  • You have to uses external software on this scanner.
  • Custom GRE/Radio Shack Frequency Table
  • Table 1 ---
  • With WIN96 software for the PRO 96/2096 scanner:
  1. Prompt "MULTI TABLES"
  2. Prompt "EXTENDED TRUNKING TABLES"
  3. Do not prompt any "STANDARD PLANS"
  4. "CH LOW" 8192 "CH HI" 12287 "BASE FREQ" 453.0250 "OFFSET" 8192 "STEP" 12.5
  5. "CH LOW 12288 "CH HI" 16383 "BASE FREQ" 450.0000 "OFFSET" 12288 "STEP" 6.25
  6. Clear all other trunking tables, and prompt "OK"
  7. Now save your file.
  • Custom Uniden Frequency Tables
  • Table 1 -
  • Base: 452.0000
  • Space: 12.5
  • Offset: 380
  • Table 2 -
  • Base: 460.0000
  • Space: 12.5
  • Offset: 570
  • If you have not done this then you will receive no audio on digital reception.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
3helpful
How can i calculate log inverse with my fx-991ES plus
By 'log inverse', you presumably mean the inverse of the logarithm function. There are two logarithm functions on most scientific calculators. Firstly [ln], or natural logarithms, to the base e, where the inverse is e^x. Secondly [log], or logarithms to the base 10, where the inverse is 10^x.
Example 1 : ln(2) = 0.69314718 so e^0.69314718 = 2
Example 2: log(2) = 0.301029995 so 10^0.30102995 = 2
Hi, how do i calculate log^-1(-2) on my ti-30xa? thank u.
The inverse of the log function is the power function.
For log in base 10 that inverse is 10 to a power of
More generally, let b be the base of the logarithm. If y=log_b (x) then x=b^y
For your case log=log_10, to calculate the inverse you perform 10^(-2)=0.01=1/100
On calculators the log in base 10 and its inverse share the same physical key. One is accessed directly, the other is the shifted key function.
I'm looking for instructions to use Back Biotek inverter or similar
Use safety strap at rear to restrict inclination to about 15 degrees when first using. Gradually increase over days/ weeks.
Adjust boom(long spine) so that you are just balanced on the table(moving your arms forward or back tilts you either way)
2answers
My 94 chevy s10 blazer is leaking power steering fluid pretty bad from the lines or pump itself. How many lines are there for the power steering pump.
the main one is the feed which is pressurised and the main cause is the flexible rubber pipe ,they perish and go porous ,take this pipe off and have the rubber part replaced in a hydraulic type place that does industrial type work ,might cost 20 euros if that
I bought a weslo inversion table at a fle market but it didnt have a mannual with it. is there any place to download one?
Hello there. Yes there is a site to download it for free. Go to
http://www.iconservice.com , then go to the manuals section,
In the model number section you should enter wlbe13320 . this will pull up a pdf file that is free to download and print.
Good Luck! Tim
No manual for Medicarn body slimmer
Try ringing Medicarn customer services in Sheffield.
01142329006
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
