Question about Canon Office Equipment & Supplies
I HAVE A cANON 3000 PRINTER AND i REFILLED THE INK WELLS AND NOW IT WON'T PRINT?i MUST HAVE TO DO SOMETHING BUT i AM AT A LOSS.
Posted by Richard Glendinning on
Lenin Hudiel
    Master:
  • Canon Master
  • 930 Answers
Even if the cartridges are full the printhead maybe is defective
Posted on Nov 21, 2020
5 Related Answers
Anonymous
SOURCE: will not print - ink cartridges not recognised, not installed properly etc
On my Cannon Pixma, I pressed the stop/reset for 5 seconds to ignore the warning. Then,
I was able to make a copy. However, better solutions to this scenario are welcome.
Cheers - Peter
[email protected]
Posted on Sep 16, 2008
Michael Bugeja
SOURCE: Canon Pixma MP220 won't print
Hi problem fixed through a previous post that is by holding the reset button for 5 seconds.
Posted on Feb 14, 2009
Ramel Mayormita
  • 240 Answers
SOURCE: Black Ink has been re-filled, canon MP240 says its empty )=
i thnk you need to replace the cartridge maybe the ciruit has been destroy in the event of refilling the cartridge..so that the computer cannot read the ink level ..
I hope it help.
thanks for using FIXYA.
Posted on May 22, 2009
Anonymous
SOURCE: how to fix my canon pixma ip1000 printer will not print black ink
replace the printer head....
Posted on Jun 25, 2009
MacD7
Printer Surgeon
  • 67 Answers
SOURCE: refilled ink cartridges on pixma mp490 ...will not print
I know this is frustrating. I am all for recycling and using refilled ink and laser toner cartridges. However, the manufacturers make most of their money from ink and toner sales. So, from time to time, they will encode or datecode cartridge chips. The only times I've been ale to get around this is by using at least one genuine OEM cartridge to trick the printer. If that does not work, try another et of refills, or you will have to use only OEMs.
Posted on May 02, 2010
Testimonial: "guru u da man. thnx"
1helpful
Canon pixma mx350 printer ink level shows exclamation mark about the icon
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
My canon mp160 printer has the color light blinking (I checked to make sure it has ink and the cartridge is in correctly) and won't print color. Thanks for any help.
Usually the cartridge is out of ink in which case get it refilled or it may be electrically failed in which case you will need to buy another cartridge.
If putting a refilled cartridge in the machine you will normally get some kind of error code, to clear this, press and hold the resume button (Black with red circle with an arrow head pointing towards you) for about 10 seconds then release it and usually you can print. The orange light will however stay illuminated or flashing.
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
5helpful
2answers
The black print won't print, but colour does, although very lightly. I have refilled the ink cartridges at Island Inkjet, so there is ink,..but black won't print at all.
your black ink cartridge got bad sprayer nozzles now you gotta replace it
and why the other color one is not bad yet cus printer as will known will depend on black ink far more so the black cartridge is heated up more times
I refilled my canon pixma ip3000 black ink cartridge and now the black will not print. Can you help?
Canon 3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
My refilled canon ip1600 ink jets are reading as empty
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Refilled Ink cartridge but the printer says there is no Ink
you refilled or purchased a new cartridge? If you refilled ; did you do it after the printer told you it was out? The cartridge electricial would have to be reset. How to do that is a guarded secret for Canon. Buy a Canon One and replace Cartridge, would one on solution.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=14991
2answers
Won't print faxes
What printer are you using?
old marine
old marine
 Grubhead
Grubhead
