Question about Photography
My coby digital picture frame will not turn on and it's connected to power adapter.
5 Suggested Answers
Anonymous
  • 28 Answers
SOURCE: Coby digital picture frame
should be able to use a memory stick or card. upload from computer onto stick/card, insert into frame & will upload pix. some frames have a USB cord that connects directly to the computer as well, if so, you can plug it into the computer (& the frame), and upload the pix you want on the frame from there (sometimes there's a program on your computer that will assist you, sometimes you just do it manually).
If this doesn't help you, please see:
http://www.cobyusa.com/?p=doc
This is the Coby website. You input the product & it will pull up all available documentation for it. Sometimes the manuals are available online.
If I've been helpful, please let me know w/ a scoring.
Thanks.
Posted on Jul 23, 2008
Anonymous
  • 88 Answers
SOURCE: Unable to download pictures from computer to digital frame
The primary software is going to extract all the images, put only the images you want on the card, then insert into your picture photo frame.
Posted on Jan 08, 2009
Anonymous
  • 47 Answers
SOURCE: I can't transfer pictures from
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Posted on Jan 05, 2010
Anonymous
SOURCE: I don't know how to make my picture frame do the
restart the whole process and redownload the pictures maybe it should work then
Posted on Mar 15, 2010
mastericpr08
Gustavo Ortiz
  • 629 Answers
SOURCE: I have an Omnitech Digital
The solution is buy a power supply in Radio Shark, bring with you the frame to see the especificaton.
Posted on Oct 27, 2010
Need a manual for Coby DP843 WD DIGITAL PICTURE FRAME.
Hi!
I'm adding a link to a list of manuals for similar Coby digital frames. Hope it will help you! https://manualsbrain.com/en/brands/coby/digital-photo-frames
Oct 09, 2018 | Photography
Can't get it to switch over to USB or mmc how do I do that to load my pictures
I'd recommend putting the pictures on the memory card and inserting it into the digital frame first, them power it on. It should automatically load that way.
Jan 19, 2015 | Coby DP-768 7-Inch Widescreen Digital...
My sreen for months hs been stuckon screen that says androidsystem recover
Try the simple stuff first ... turn the picture frame off. Then remove the AC power adapter from the a/c socket in the wall. Wait 30 seconds then plug the adapter back into the wall outlet. Turn your picture frame back on and notice any error messages that may get displayed.
Jun 06, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
Why wont my digital photo frame turn on?
If you have not already done so, try another power adapter. In some cases, the cord between the power rectifier/step down transformer (the part that actually plugs into the AC outlet) and the connector at the frame end, becomes kinked or broken. The connector at the frame may also have become worn and not propely connected? If a second adapter does not work then the unit is faulty. Take it to your nearest service center for repair. (it may be less expensive to purchase another digital frame?)
Dec 20, 2012 | Philips 7008 8-INCH DIGITAL PHOTO FRAME
I have a 7 inch Coby digital frame and it only shows half the screen, how do I reset?
there is no reset on the frame itself, when you turn it on, it should show a blue screen with coby logo, if this is also halfed, then the screen is broken.
Mar 06, 2011 | Coby DIGITAL FRAME COBY DP102 RTL
Mar 14, 2010 | Coby DP-772 Digital Picture Frame
Digital Royal Key Chain - How do I download pictures?
Hi, the Digital Royal Key Chain has a mini USB port located somewhere, this should also be the port for the adapter to the built in lithium battery inside. There after, just plug in your computer and Plug and Play software should detect it. Then you can move your picture files, (.jpg, .mpeg, .gif, etc) and drag them in the drives folder. They should display then.
Mar 15, 2009 | Coby DP-768 7-Inch Widescreen Digital...
Thanks.
Jul 23, 2008 | Electronics - Others
Photography Logo
Top Photography Experts
Ekse
Marvin
Marvin
Are you a Photography Expert? Answer questions, earn points and help others
