Can this converter box be hooked up to a Firestick and work without an antenna?
Posted by Shafeqah on
    Top Expert:
  • Televison & ... Master
  • 76,749 Answers
NO
It cannot.
Posted on Sep 14, 2021
  • Larry Sep 14, 2021
    How can you answer no when you have no idea what box he has
5 Related Answers
Anonymous
SOURCE: converter box
1) Connect the coax cable from the antenna to the converter box input.
2) Connect the coax cable output of converter box to the input of the VCR.
This is the only way it will work but you will have many limitations such as using the programming features of your VCR.
The boxes are fine if you want to play prerecorded DVDs or tapes. If you want to record tapes you have to leave the box on and have it set to the station you want to record.
Posted on May 30, 2008
Anonymous
SOURCE: Hook up Converter box
if you have cable or satellite, you do not need these boxes
Posted on Jun 13, 2008
Anonymous
SOURCE: insignia digital tv converter/indoor antenna no signal
I had the same problem but realized that when it said NO SIGNAL,,,,it just ment for that station,,,,,switch channels and they will start to come in,,,
Good Luck,
charh20
Posted on Feb 22, 2009
Anonymous
SOURCE: Converter box turns off by itself when watching tv.
Check the settings in the menu--many boxes have "power save" mode and will shut off after anywhere from 2-12 hours of inactivity. You should be able disable it or change it to a longer time.
Posted on Mar 14, 2009
Anonymous
SOURCE: Hook up old tv antenna to converter box
how can i connect inside anntena to the tv and converter box?
Posted on Oct 16, 2009
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
1helpful
Attenna hook up
Yes, This set does not have a digital tuner built in. All over the air signals are now digital. This set will work without a converter if hooked up to standard cable,DVD,VCR or Video game console. If you purchase a DVD with a digital tuner built in you can skip the converter box and hook your HDTV antenna directly to it.
1helpful
I have an older TV with only an antenna hook-up, a VCR, a DVD recorder and a converter box that I would like to hook all together. I can get the VCR to work, but don't really know how to hook the DVD...
Try this. You will need 2 RF cables and a RCA cable that has a red, black, and yellow plug on each end.
  1. Plug the antenna signal into the converter box.
  2. Connect the RF output (TV out) of the converter box to the RF input on the VCR
  3. Connect the RF output (TV out) on the VCR to the TV
  4. Finally, plug the DVD recorder into the converter box also, but use the 3 RCA cables that came with it (audio left, right and video).
Converter boxes hook up
u need a stronger antena , best check without the converter box and see if u get chanels , if u do hookup the antena to the converter box then to the tv and do the scan again , move the antena to diferent places
Do you need a special antenna to hook up a dtv digital to analog
You need a TV antenna, nothing special about it. Hook the antenna up to the converter box, the box up to the TV.
3answers
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Hooking up a convertor , when i have a vcr, dvd player
You can hook it up through the antennae system. Keep your dvr connected to the tv the way you had it. Hook up your TV rabbit ears antennae to the converter box in the connection on the left side of the box. Then hook up the antennae lead from the converter box to your TV on the right side connector. The only thing I'm wondering is, do you get stereo sound this way and does anyone know how to get it without hooking up the separate audio and video plugs? There aren't enough connections on the tv to hook up both sets.
Converter Box / DVD Recorder
Here is a great article on differnet hook up options.
Click HERE
Televison & Video Logo
Top Televison & Video Experts
Ekse
