Getting my color back on my tv I hit a wrong button and I need help restoring it
Posted by Susan Hague on
Larry
  • Televison & ... Master
  • 3,133 Answers
Model and make would be helpful, here is a generic answer, go to picture settings scroll down to color, it's usually before or after sharpness, if you have no color it will be on 0 turn it half way up
Posted on Sep 14, 2021
    Top Expert:
  • 76,749 Answers
Try a reset your set, and then try. If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
3 Related Answers
kevin mennor
SOURCE: hit wrong button on remote now i have no sound
heres a website called universal remotes---click on comcast on left--click on the pic. of your remote and on left side click on unlocking remote buttons
www.urcsupport.com
Posted on Dec 10, 2012
Terry Corrow
johnny rebel
  • 10875 Answers
SOURCE: What is wrong when you getting power to the TV but it want stay on I hit the power button but the TV turns itself back off
backlight is bad
Posted on Jun 13, 2015
richie46
  • 12962 Answers
SOURCE: My tv screen shows only colors after I hit a wrong button No picture.
Check T con board.
Posted on Sep 16, 2015
Tv lost color, now just black and white. any way to correct this problem?
Try going into the menu on the tv. Once you are in the menu look for "restore factory defaults". Restore the tv back to factory. If this doesn't get you your colour back then i would suggest that something more serious is wrong with the tv
Hit wrong button on remote now i have no sound
www.urcsupport.com
2answers
I have a 61
Dial the tint adjustment
Sound no picture
I think you hit the wrong button before....
To restore the settings please try to restore factory setting and see what happen..
I hit the remote on button the 52"samsung tv
Tries tv unplug,replug it back like about an hour later.For the tv to resetting itself back to the factory setting,it should be working again.If it is still have the same problems,the causes mostly the power supply board have the problems,that the board where the power a/c cord plug into it.Tries websites like a Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
1helpful
How do I change imput back to tv from video I have time warner cable and hit a wrong button turned to video now cant turn back to tv How do I do that?
Well not knowing the TV brand or model I would say you need to look either on the TV itself or the remote for an input button. some times called mode or source. Some you may have to hit it multiple times to get back to select to the cable input.
Hope this helps and good luck.
2helpful
RED COLOR NOT coming on TV, showing green all over place
I also have a samsung 40 inch. Try hitting the menu button on the remote the scrolling over to the right once and scroll down and hit pictures reset to see if that works. If it doesn't check your connections coming from the back of the source and the tv itself.
Magic focus problem
in the menu first check if focus is set to auto or manual, need to be auto, if it is then pop off the front cover and acess panel with TV on cafefully press small button on signal pcb front edge, this is service mode, press pip mode,then pip channel after intialize turn TV off then on, function should be restored.
I NEED HELP IN STOLLING MY NEW DVD PLAYER
good day,
just make sure that the colors are matched with the jock and the socket in your dvd player and your tv. just make sure that you unplug first your dvd player and tv while attaching the wires to avoid accidents.
just follow the color coding of the wires and cables and you wont go wrong. just plug in the your tv and dvd player to the electric socket and in no time you will be watching your favorite movie.
for the player, just press the open(eject) button to insert your dvd and normally it will automatically play. just hit rewind (<<) for playback and forward (>>) to skip some scenes. use the |<< button to go back to a previous section and the >>| to skip to the nest section. use the || to pause and the button with the square symbol to stop.
i hope this would help.
Televison & Video Logo
Top Televison & Video Experts
Ekse
