SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
SOURCE: garbage disposal (water won't drain out of sink standing water)
There should be an overload button somewhere on the bottom of the disposal motor. This is to prevent the motor from trying to run if the chopping blades are jammed, otherwise the motor would burn up.
First, try to move the blades with something like a broom handle. Using a flashlight you should be able to see the blades. there's probably three of them. try to make sure each one can move even a little bit.
Next, with the disposal switch in the off position, find the overload button and push it in, Then turn on the disposal switch and see if it runs. If the overload button trips off again, repeat the above steps until the blades can turn.
Let me know how this goes. Loringh
SOURCE: garbage disposal doesn't drain
Sometimes what happens is that when they install a garbage disposal the pipe coming out of it ends up being lower than the pipe exiting the pea trap thru the wall under the sink. If it is a dual kitchen sink this is very common. Being lower than the exiting pipe causes water to stay in the bottom of the disposal and not just the pea trap. If you have a side by side sink in the kitchen and the water is backing up in the other sink also then more than likely the pea trap has a blockage. It is not common for the straight line from the pea trap going thru the wall to become blocked, but it does sometimes happen. The biggest cause of this is poring hot grease down the drain. It is just about the point that it cools enough, sticks and hardens plugging the drain pipe.
You probably should have a plumber look at it and make sure everything is running downhill under the sink. The only place that water should set in the plumbing is in the pea trap so that odor from the sewer does not come up into the house. Without actually seeing it, it is hard to tell exactly what is happening. The pea trap is easy to clean, put a really big pan under the trap, make sure you have emptied as much water out of the sink as you can, then with a big pair of channel locks unscrew the two nuts that hold the pea trap in place and let the fluid drain from it, then finish unscrewing it from the pipe. You can then clean it out and check the pipe thru the wall for blockage. When reassembling it, screw it all together loosely and then move the pieces around while hand tightening each joint so the they have no pressure on them, then use the channel locks to finish tightening the nuts. Don't over tighten them because they have nylon seals in them that compress to make the seal. Just tight enough to seal and not leak. You should be up and running again unless the plug-up is farther down the wall pipe. Good Luck, RAC
SOURCE: Used reset button, the motor runs but the blades are not turning?
sound's like you have a problem with your drain pipe's. it is not normal for water to come back up.check the allen key bolt, located on the bottom of unit .insert allen wrench /key,and turn in a clock wise&counter clockwise motion to see if disposal is jammed.you also might consider some drain opener before it get's worse
Testimonial: "Thanks for the info. Unjammed it like you stated and used drain opener. Walah, it worked!"
