Question about Mitsubishi Televison & Video
Mitsubishi DLP TV model WD-57733 status indicator light is steady yellow indicating overheat.
Posted by joe oneill on
Attique-ur-Rehman
    Top Expert:
  • Mitsubishi Master
  • 2,677 Answers
If the status LED shows a steady yellow, that means the DMD temperature has gotten too hot. If the status LED is blinking yellow, that means the lamp cover is open. If the status LED is blinking red and then blinks yellow, that means you will need to follow that code to find the problem with the TV.
https://www.youtube.com/watch?v=INird71KKtA
Posted on Apr 24, 2020
3 Related Answers
Anonymous
  • 60 Answers
SOURCE: MItsubishi DLP HDMI HDTV WD-62525 Steady RED
  1. Call Mits. and see if they will cover the main chassis rebuild then call an authorized service center to pull the chassis will take 4-8 weeks for it to be rebuilt but you will be resposible for labor
Posted on Aug 25, 2009
intk50
  • 84 Answers
SOURCE: I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Posted on Mar 09, 2011
techman007
Lavell Turner
  • 1112 Answers
SOURCE: My Mitsubishi WD-52527 TV has
Replace you lamp again but this time do not use generic lamps or off manufacutred lamps. use Genuine Mitsubishi lamp.
Posted on Aug 24, 2011
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
Wd-82837 status light blinking tv tries to turn on blue sreen comes on then tv shuts off.
My status light is flashing and I cannot get an indication that the TV is actually on. There is no sound. I cannot get any display whatsoever. The blue light across the bottom is not on. Thus, the TV is probably on in the 1st place. Ideas?
Sep 22, 2012 | Mitsubishi WD-82837 82 in. HDTV DLP TV
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Want does yellow light mean
If I'm not mistaking I believe Mitsubishi shows the yellow light to indicate new bulbs needed and or overheating. Most common is overheat, but may actually be a bulb replacement required.
http://www.mitsubishi-tv.com/pdf/ownersguides/WD-73733.pdf
That is the manual for your TV
Mar 10, 2011 | Mitsubishi WD-73733 73" HDTV
Bill W
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
Steady Yellow Lamp Light on Mitsubishi WD-52628
no its just indicating that the lamp is reaching the end of its lifespan,
Mar 15, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
