Question about Phantom Video Game Consoles & Games
When i power on my phantom 3 standerd it starts to beep and my remote wont conect to it ?
Can someone fix a DJI Phantom 3 please?
Take it to your local repair facility - fixya does not provide technicians.
Apr 19, 2017 | DJI Innovations Phantom 3 Professional...
My mic wont respond when I plug it into my laptop or PA.
The SM87 requires phantom power. Plug it into a mixer that has phantom power and make certain the phantom power is turned ON on the mixer.
Feb 22, 2014 | Shure SM87 Professional Microphone
Hi i purchased an NT1-A mic . But after installing the cable to the mic . The mic does not respond. I had tried my previous mic and it works instantly.I suspect its faulty .
did you conect the phantom power? even if you conect the phantom power in the mixer it will not work if you use a cable unbalenced.
Feb 09, 2011 | Rode NT1A Professional Microphone
Mic to PC
This mic is a condenser type microphone. It needs phantom power (48v) to operate. Might want to buy a USB mic preamplifier box, like an M-Audio product, which will provide phantom power, xlr/1/4 inch inputs and USB output.
May 23, 2010 | Behringer C-3 Professional Microphone
Hi,made connection by use of HDMI cable from ps3 to tv with no problem.But now i wont to conect to tv which doesnt have aHDMI point.So i have got a SCART Lead which conect to ps3 to tv and i have an AV...
turn on your ps3 (with your tv also on) and hear the ps3 start power beep. after you hear this normal beep, press and hold the power button for 5 seconds till you hear a beep then let go of the button.
This will reset the outputs and resolution to defaults and you should get your display again, if you don't then the ps3 has a fault.
Jan 02, 2010 | Sony Playstation 3 (PS3) Console
We just installed yesterday. Ran it with remote for about 3 hrs, on and off, tested speed, reverse, all worked. Come back 5 hrs later and go to turn it on and it does not work. Usually i hear a beep when...
The beep comes from the receiver in the fan hub. If no beep, I would suspect the receiver is not responding to the remote.
Reasons could be:
- loose connections to/from receiver or,
- with bad luck, the receiver could have failed already (loose conections could cause premature receiver failure) or,
- the fan pull-chain switch is off -- your scenario does not allow for the chain being pulled during the 5 hours the fan was not run, but who knows... or,
- receiver/remote are out of synch (set on different frequencies). Are there dip switches in receiver/remote to set frequency, or is the frequency set by the remote with a combination of button pushing? If the latter, maybe the frequencies for the two are were accidentally set out of synch...
More info, let me know...
Charlie
Sep 25, 2009 | Casablanca Fan 6646T Panama® Rustic Iron...
Behringer B-1 Will Not Pick Up Anything
The microphone needs a phantom power supply to work. In your case you need a 48volt phantom power supply. Some mixers have this feature built in.The Micropower PS400 by Behringer would probably be a good choice.
Apr 19, 2009 | Behringer B-1 Professional Microphone
MY PS3 WONT LOAD UP AT ALL NOT EVEN TO THE MENU PAGE, EVERYTHING IS CONECTED PRPERLY BUT I JUST GET A BLANK SCREN
hold the power button untill it beeps three times and turn off.
hold it again until it beeps twice, then two times real quick and let go right away.
select option 3, and it will repair hard drive two times..
and voila!
Feb 23, 2009 | Sony Playstation 3 (PS3) Console
1999 toyota camry horn beeping when i replace the battery
I put a new started in my 99 camry the alarm went off and I didn't know how to stop it ,now my car doesn't have any power the battery is new but its not giving my car any power.Help...
Aug 20, 2008 | 1999 Toyota Camry Solara
Video Game Consoles & Games Logo
Top Phantom Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Phantom Video Game Console and Game Expert? Answer questions, earn points and help others
