Question about Panasonic Televison & Video
HDMI port on my 46 inch panasonic flat screen tv quit working. What can i try to fix it?
Posted by Jerry Sherrill on
Dariusz Zalewski
  • 1,093 Answers
Try different cable first
Posted on Jan 11, 2020
Testimonial: "I have plugged the cable into another tv and it works"
Has audio, but why did screen go black?
since the self generated menu displays ok id say you don't have a monitor problem , could it be that maybe somehow it got switched over to maybe an "open" input port (example: hdmi-2) as this would explain things a bit , also when you tried the other tv did you use the same cables to connect it as the non working tv ? as that also would explain things
Feb 09, 2016 | Panasonic Viera TC-P46C2 46" Plasma HDTV -...
HDMI Ports on Toshiba Flat Screen TV stopped working
That's highly unlikely!!! More likely is that the cable is having problems or that someone mistakenly changed the picture i the TV from HDMI to regular reception. If the HDMI ports are changed to regular TV reception they don't see the HDMI ports only the regular video ports!
Jan 01, 2013 | Televison & Video
Trying to connect hdmi cable to laptop to watch movies
Are you sure you have four hdmi ports? I have only one hdmi port and three usb ports. Be sure you are connected to the hdmi port and for some reason not a usb port.
Aug 17, 2012 | Sanyo DP46849 46 in. HDTV
We have a panasonic 32"inch lcd tv.we want to
hdmi Ports Qty 3 port(s) PC Interface VGA (HD-15) HDCP Compatible Yes
I read your tv has 3 hdmi ports and a PC input.
if your pc has hdmi out - the you use a hdmi cable from the pc to the tv on one of the hdmi inputs.
if your pc has a 15pin vga cable you can unplug from your PC monitor (or go buy a VGA cable if you want to keep one on the tv and one on your pc monitor - or if you are using a laptop).
when you unplug the computer from the monitor .. check the pins - should look to be about 15 pins in the connector. it that will plug into the tv- then you are using a vga cable. if it will not plug into the tv pc input .. don't force it. It could be a dvi connector . .take the cable off the PC and to radio shack and they can fix you up (you need a dvi to vga cable - not likely, but possible)
I always turn off a pc before disconnecting monitors - and plug into the other display before turning the pc back on.
Good luck.
Bill.
Nov 29, 2010 | Panasonic TCL32U22 32 in. TV
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
HDMI ports do not work after lightning storm
Probably not, but your insurance should pay if you have a renter or homeowner policy.
Jul 21, 2009 | Panasonic 50 in. Plasma TV
Westinghouse 47 in LCD HDTV
cfusion.com has the mainboard for that. it sounds like you just need a new one, it looks like its about $169
Apr 07, 2008 | Westinghouse LTV-46w1 HD 46 in. LCD...
Televison & Video Logo
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
