Question about Lands Phones
What does the number 11 next to my name mean? It used to be 10
Posted by Carol Pike on
  • Andrew Taylor
    Andrew Taylor Jan 11, 2020
    Due to scripting glitches on the site and my computer I am replying via my phone. Please see my post which I have edited.
1 Related Answer
SOURCE: write a programme that takes
Since you are taking a class in binary programming; I would recommend you figure this out yourself. The major point in logic class is to determine ways to solve this on your own. If you are unable to do this; I would suggest a change of major.
Posted on Jan 29, 2011
What does E2 mean in display window?
The "E" means that the glass has been approved for road use in Europe on European member licensed automobiles by the Economic Committee of Europe (ECE). The number next to the "E" indicates the country which approved the item.
The numbers are as follows:
1 - Germany;
2 - France;
3 - Italy;
4 - Netherlands;
5 - Sweden;
6 - Belgium;
7 - Hungary;
8 - Czech Republic;
9 - Spain;
10 - Yugoslavia;
11 - United Kingdom;
12 - Austria;
13 - Luxembourg;
14 - Switzerland;
15 - (vacant);
16 - Norway;
17 - Finland;
18 - Denmark;
19- Romania;
20 - Poland;
21 - Portugal;
22 - Russian Federation;
23 - Greece;
24 - (vacant);
25 - (vacant); and
26 - Slovenia.
Mar 05, 2018 | In Office Equipment & Supplies
11 microgram convert to kilogram
11 micrograms = 1.1 × 10-8 kilograms
1 microgram = 1.0 × 10-9 kilograms
So for the future multiply 1.0 x 10-9 by the number of micrograms you have to get the number in kilograms
Jun 21, 2011 | Texas Instruments TI-83 Plus Calculator
When calls come into the office ext. 10 rings. It's the receptionist's desk. However ext. 29 rings too. How can I stop ext. 29 from ringing on all incoming calls?
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Oct 26, 2010 | AT&T Lucent MLS-12D Phone
Serail number of acronis true image
There are two keys which might work with as per your edition : Acronis True Image 11.0 HOME s/n: R3LN8-T98EA-Y3LHA-WXR4U-PJ3E9
Acronis True Image 11 Name: Noc s/n: PS4J2-EYXFC-HK47C-ZU2NC-PZNTK
May 19, 2010 | Acronis True Image 10 Home Full Version...
Assign a new person to an extension
Changing the programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
press the left hand intercom button
the display should say central telephone prog extension:
enter in the extension number of the persons phone you wish to rename
the display should say program extension xx
the display should say the extension number followed by the existing programmed name
enter in name of new person by pressing the number where the letter is then its order on the button so under the 2 button 1 would be A, 2 would be B, and 3 would be C ex. BILL = 22 - 43 - 53 - 53 use the mic/hfai button to erase entry.
either press the right hand intercom to go to the next extension or press feature 00 to exit
Oct 19, 2009 | Avaya Corded Phone avaparp18d
How do i install an epson lx 300 printer to a vista machine using a parallel to usb converter? i can't locate nor create usb 001 port with the driver cd of the said printer.
1. Start
2. Settings
3. Printer and Faxes
4. Add a printer
5. then Next
6. then Next
7. then Next
8. then Next
9. select Manufacturer name : Epson
10. select Printer name : Epson LX-300
11. Next
12. Windows will automatically install the driver for your Printer
Jun 21, 2009 | Epson LX-300+II Matrix Printer
Initialising Mailbox
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
To Change the "Recorded" Name for the Company Directory:
1. Have the Voicemail User log into their mailbox, after putting in their password, press the button under "Admin" (or press the number 8 key., and then press the number 1 key.
2. You will hear the old recorded name and then the system will "beep", prompting you to record a new name (name only here, not greeting..
3. Press "Ok" in the window when you are done recording and then "Ok" again to accept the recording
Apr 23, 2008 | NorStar M7310 Corded Phone
MP3 playback stops at the last file in folder and does not continue to next folder
Not much you can do.
You could rename all your tracks, and put them in one folder.
EG
ALBUM NAME - 01
ALBUM NAME - 02
ALBUM NAME - 03
ALBUM NAME - 10
ALBUM NAME - 11 ETC.
This way, the tracks will play in order within each album.
Use 2 digit track numbers or they will play 1,10,11,2,3,4, etc
Mar 17, 2008 | Televison & Video
Playlist problems
The only way you can get the tracks to play in order is to rename them before you put them on the player.
eg.
Album title - 01 - Track name
Album title - 02 - Track name
Album title - 03 - Track name
Album title - 10 - Track name
and so on
The albums will stay together, and the track number will put them in order within each album. Just remember to use 2 digit track numbers or they will sort 1, 10, 11, 12, 2,3,4,5,6,7,8,9
Mar 07, 2008 | Philips GoGear SA178 MP3 Player
Lands Phones Logo
96 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
