Question about Baby Gear
My monitor baby is a summer 28630 n keeps sayin cam 1 with a. there is no pairing button just a button that says code
Posted by jay lomzky on
David Maria
You should to change default setting and reset, Always buy best baby monitors in the market. for more info visit here https://buybestbabymonitor.com/
Posted on Apr 10, 2020
4 Related Answers
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: summer infant baby monitor
Need to clean and resoldering works.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click to rate.It is the only way i get paid for my work...
Good luck:
Posted on Jul 25, 2008
Anonymous
  • 12 Answers
SOURCE: Hello, My summer flat screen,
Hello jesslsch,
For a problem like this, there's pretty much 3 solutions.
1) You could grab a piece of scotch tape or some other adhesive and stick the button into the "on" position
2) Bring it to a local electronics repair shop to get it professionally fixed
3) Purchase a new unit
I hope this information has been helpful.
Posted on May 25, 2011
Micoman
Jorge Luis
  • 198 Answers
SOURCE: I am having another baby
Yes, you can add other monitor
http://www.ebay.com/itm/Summer-Infant-Best-View-Digital-Color-Video-Monitor-White-/370544520105?pt=LH_DefaultDomain_0&hash=item56462caba9
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Posted on Sep 20, 2011
phil_hick883
Phillip Hicks
  • 917 Answers
SOURCE: How to pair VTech baby monitor BM3100 it has worked for 1 night unpaired itself and will not repair??
If bought from a shop , take it back for replacment , as faulty
Posted on Mar 15, 2015
1helpful
Baby monitor will not sync
I just barely had this problem and was able to figure it out.
You need to hit the "ok" button on the side of the handheld monitor. It will only let you select "add camera".
Hit ok again and it will give you a list of 4 camera's.
Now at this point you will need the actual camera and handheld monitor. You need to hold down the "code" button on the back of the camera and select "camera 1" in the list of 4 cameras. This should sync it back and you should have picture again!
Monitor says no signal, no picture or sound
Step 1: Move the Monitor to the same area as the CAMERA. With
the Monitor on, press the Menu button on front of Monitor and using
the Scroll button move down to the "ADD/DEL CAM" option. Press the
Scroll button to select "ADD/CAMERA".
Step 2: At the same time press and hold the scroll button on the
monitor and the pairing button on the CAMERA for at least 5
seconds. Then release.
Step 3: You should then see a picture from the CAMERA on the
Monitor.
Step 4: If this is unsuccessful, you will see the message "OUT OF
RANGE" on the Monitor screen and should repeat steps above
making sure the CAMERA and Monitor are close enough to each
other for pairing.
1helpful
How do I sync other cameras to the baby monitor?
just decide which camera you want next one to be so say camera 2 on your monitor and on the back of the camera you want to add there is a pairing button press it and it will pair, and the just add on to the next one say camera 3 if you have another camera just press the pairing button on the camera your adding each time
9helpful
My camera is saying out of range can you help
Turn on both camera and monitor. Bring the monitor close to the camera. Press menu button and scroll down to "add camera"
Press and hole the pairing button on the back of the camera and press and hold the centre button on the monitor and hold for a few seconds. The monitor should soon show what the camera sees. Then just close up menu.
Hello, My summer flat screen, color baby monitor on/off button is broken. If I hold the button in it stays on but it will not stay on without being manually held in.
Hello jesslsch,
Green light on and no sound or picture
Turn on both the camera and monitor. Press the power button on the front of the monitor to access the camera selection menu. Make sure your unit is set to "cam 1". This should fix the problem.
88helpful
2answers
My summer best view handheld video monitor says out of range and will not pair.
Have you tried pressing the pairing button at the back of the camera unit and press the scroll button at the center of the receiveing monitor at the same time as suggested by the manual? I had the same problem, followed the manual instructions and solved it. (Greetings from Mexicali, M
8helpful
Had summer baby monitor for eight months, last night it stopped
Your monitor has become unpaired with your camera. Follow the instructions in the manual to pair them again (basically, tell the monitor piece to Add New Camera while you press the Pair button on the camera). The manuals can be downloaded from www.summerinfant.com.
My baby monitor summer zoom pan has deleted the camera and won't let me add it on. Says no camera! HELP!!!
take the monitor to near the camera put the monitor to which camera say camera 1 and then on the camera there is a pairing button press it and thats it.
Baby Gear Logo
Top Baby Gear Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Baby Gear Expert? Answer questions, earn points and help others
