SOURCE: Freezer gets cold but doesn't freeze
check tem.p inside cabinet and let us know what you find
SOURCE: I have lost my turnkey for an Imperial Upright
you can visit the website of the company and make a request for the key or get the door forced it to get open and get a new locker key for it.
SOURCE: I have a Superior heavy duty commercial upright
I have a superior hd freezer it is working but the out side sides get very hot any idea
SOURCE: We have an imperial upright ''commercial grade''
just to be sure that your door is sealing properly, put a flashlight into the freezer and turn off all of the lights in the
room to see if there are any openings in the seal. Iam suggesting you this coz sometimes a small opening may pass our eyes easily....
if the door is sealing properly......
If this is the type of freezer where the shelves are the evaporator
coils, the coolant goes through the shelves(tubing) and the formation
of frost is normal and has to be manually defrosted.All the shelves
should be as cold asd the top one. The fact that just one has any frost
may indicate that it is low on freon. If this is the case you should
notice that the freezer doesn't get cold enought just like you said... so check your freon levels.
This could also be because of the thermostat not sensing when the fridge
reaches its set temperature and as a result of this the compressor will
keep on running and build-up of ice will occur.
Follow the advices in the order prescribed above and you should be set
