Question about Speidel Watches
My wife has a speidel watch. No notches to unscrew. I have checked to see if it had a sweet spot but I don't see one.
Posted by Bill Pinchin on
Simon Atkinson
  • 2,107 Answers
Not all watches are fitted with a notch or a 'sweet spot'. Some just need a thin, hard edged tool to lever the back cover off.
**DON'T use a sharp knife blade as this scratches the watch and slices your fingers.**
I use an old, blunt, broken butter knife I've modified to give me a curved edge to work with.
Posted on Mar 19, 2020
1 Related Answer
gopakumarg43
  • 76636 Answers
SOURCE: What is the value of this watch in good condition
30USD
Posted on Jun 09, 2014
1helpful
I'm looking for the worth of a ladies Bulova watch with 10K Rolled Gold Plate L3 1131948 on the back.
i have a bulova same no. speidel pat. but the serial no. u lookin is different this one is 10kt rolled gold plate back.
Oct 20, 2011 • Watches
Water inside
you need to open the back plate of your watch and sit the watch in a dry warm area for atleast 24 hours to allow the water to evaporate and dry out..to open the back If the back plate of your watch is smooth around the edges, then it will pry off. Look carefully around the edges for a spot with a small gap, which it may or may not have. Prying gently with the tip of a sharp knife, usually with a light twisting motion, will pop the back plate off the watch. It simply presses back into place with moderate-to-light pressure. IF the back plate has notches around the edge, it need to be unscrewed from the back. Harbor Freight has a cheap tool to engage these notches and turn the plate, but I've had good luck simply using the tips of a needle-nose pliers to engage these notches and unscrew the plate.
1helpful
I have a ZR11622 I can't get the back off to replace the battery!
The back of your watch is attached in one of two ways. Look at the watch back. If it's smooth all around the circumference of the back, you have a snap-fit back. If, however, you see little notches cut into the edges--if they were extended, it would make the back look like a pizza that's been cut into slices--then you have a back that screws on and off.
A snap-fit case back often has a small (very small) raised section at one spot of the rim; this is so you can insert a tool called a case knife and pop the back off. If you don't see that small raised section, you'll need to wiggle the blade of your case knife under the edge and gently apply leverage from there--it's usually easiest by one of the watch lugs, as opposed to near the watch crown. If you don't have a case knife, you can often use a thin (but tough!) knife blade to do the same thing. Remember, though, that applying this much force through a knife blade can distort or take a chunk out of your edge, so be prepared to sacrifice a knife or be prepared to re-sharpen it after this exercise. A screwdriver does not work very well; the blades are typically too narrow to provide good leverage without distorting the case back, and they may even cutt a gouge into the watch body. Avoid using them for this purpose. To increase the water resistance of watches, Relic case backs are often very tightly fitted--they're tough to get off, and even tougher to push back into position. I would not be surprised if you would need a jeweler's press to get the back of this watch back into position.
If, on the other hand, you have a case back with notches in it, you will need to unscrew the back of the watch. You'll need a special wrench to do this. There are lots of makers and models from a basic $5 "watch crab" to a $100 workbench-mounted device that works on all kinds of watches, including Rolexes. Again, because screw backs are usually tightly fastened to increase water resistance, simply using a pair of needle-nose pliers in the ridges probably won't work. Nor will using a screwdriver in one notch--these backs are designed to move when equal pressure is applied around the edges, and applying force in one area only locks things up. Under no circumstances try to pry off the back if you have a screw back -- this will damage the threads, and you'll probably never be able to get the watch back together again.
You can find case knives and case wrenches at many jewelry supply stores, mail order supply houses like Otto Frei (http://www.ottofrei.com/store/home.php?cat=296 will take you right to the watch repair tools), and on eBay. However, if you're near a Harbor Freight store, they sell a "watch battery changing kit" and jeweler's press for an extremely reasonable price. These aren't the ultra-high quality tools that a professional jeweler would use, but they'll be perfectly fine for changing the occasional battery for many years. I've probably closed 100+ watches using the inexpensive press I got from there.
How do you remove the back to replace the battery. Does the back unscrew or does it snap off.
if its flat with no notches then you can use a pocket knife or small flat blade and look for a notch underneath the case back, there is usually an indentation where the case remover can slip in . Then you have to carefully force the knife inside and wiggle it up and down till it pops off. Be very careful you can cut yourself doing this or even damage the watch by slipping the blade inside and ruining the movement.
If it has a screw back you would see notches on the back of the case going around the diameter usually 6 or so notches. There you would need a special watch opener tool that fits into those holes and would unscrew it.
I would recommend taking it to a fast fix or batteryplus for about 7 dollars you can have them replace it. That way you can prevent yourself from ruining your watch or hurting yourself.
if you do open the watch up be careful not to touch the copper coil if you scratch that you will ruin the movement and need that replaced. if its flat with no notches then you can use a pocket knife or small flat blade and look for a notch underneath the case back, there is usually an indentation where the case remover can slip in . Then you have to carefully force the knife inside and wiggle it up and down till it pops off. Be very careful you can cut yourself doing this or even damage the watch by slipping the blade inside and ruining the movement.
I would like to remove links from my expandable watch band
Can I be honest? These are not easy to do. Ive done hundreds and I hated doing each one. You can try yourself but I would take to the dealer who sold you the watch, or to a local watchmaker. If you still want to do on your own, here is a link to a Speidel band that does a pretty good job with instructions. Best wishes.
http://www.speidel.com/default.cfm/PID=1.24?PID=1.24&inq_key=7851&action=detail&LibID=465
I traying to find a band for my watch is metal but i do not know it model it call seiko kinetic SQ 100 it is golden all around with white back ground and it has a calender
You can try Seiko for the band. That band is pretty common in both Seiko current models and after market brands such is Speidel.
There is a 18mm metal band that is almost exact from Bariloche available in some watch repair and accessory stores. You can also check Speidel.
Sep 17, 2009 • Watches
Watch casement cover replacement
looking for a battery cover to suit model D 377 tissot men's twotimer II vintage 1992.
Jun 19, 2008 • Watches
Watches Logo
Top Speidel Watches Experts
Lisa Christine
Lisa Christine
john h
Are you a Speidel Watch Expert? Answer questions, earn points and help others
