Question about Refrigerators
Bulb replaced but FREEZER LIGHT still not working
Posted by Lynn Brownlee on
David Spradling
    Top Expert:
  • Refrigerators Master
  • 11,389 Answers
Check voltage on switch if not when should be on bad switch if no voltage bad board
Posted on Jan 28, 2020
2 Related Answers
arikrom
911 SERVICE TODAY
  • 528 Answers
SOURCE: Replaced light bulb, still not working, also
the control panel need to be replace :( not so cheap but it happen to me also.
Posted on Jan 01, 2010
craig cole
  • 17 Answers
SOURCE: maytag Serial Number 2256KEQ3 - Freezer light will not work - Bulb has been replaced
change switch contact bad
Posted on Jul 15, 2012
How do I fix the freezer light in my Whirlpool side-by-side/freezer on bottom fridge?
first make sure the light bulb works for sure. then most likely it is the door switch. easy to replace. pull out, disconnect and replace. while you are at it, touch the two wires together and make sure the light goes on so you know it is the switch.
Aug 09, 2015 | Whirlpool Refrigerators
How do I replace my freezer light
An owners manual I found online says:
Freezer
  1. Pinch rear tabs on light cover and pull straight down.
  2. Remove light bulb.
  3. Replace bulb with appliance bulb no greater than 40 watts.
  4. Insert front tabs of light cover into freezer liner and snap rear portion over light assembly until rear tabs engage.
The manual illustrates the bulb is behind a plastic grille right by the temperature control knob.
Aug 05, 2014 | Amana ARB1917CSR Bottom Freezer...
Light bulb is not working. how to change it and what kind of bulb is it model: FKFH21F7HW
Good Afternoon Rose, I am happy to assist you!
Before replacing the light bulb in your Frigidaire freezer please confirm that the temperature control is set in the OFF position and unplug your appliance to avoid electrical shock. Typically, you may remove the light bulb by turning it counter-clockwise. The old bulb can be replaced by an equivalent watt bulb (part number is 216988100) available either from part distributors or hardware stores. I hope this information helps to some degree!
Feb 25, 2014 | Frigidaire FKFH21F7HW Freezer
Skandiluxe freezer seals
Hi
Most freezer lights are screw on bulbs. Unscrew the bulb unticlockwise and replace with a new one.
Feb 15, 2014 | Freezers
How to change a bulb in the Kenmore refrigerator
Most likely, you never notice the light bulb in your freezer or refrigerator until it is not working. Then it is time to replace the bulb. This is especially important with freezers, which are often in areas with poorer lighting, like basements or garages. Fortunately, the task is a simple one.
Instructions
1 Unplug the freezer to prevent an accidental shock when you remove the light bulb.
  • 2 Open the door of the freezer, look at the top inside edge of the freezer, below the door seal and back about 1 to 2 inches from the edge. You will see a small plastic or metal panel that protects the bulb from damage and shields your eyes from the direct light of the bulb when the door is opened. Reach behind the guard and remove the bulb by twisting it to the left.
  • 3 Put your new bulb in by inserting it into the socket and twisting it to the right to screw it in. Be sure you use a freezer bulb--it is built a little tougher and is the correct wattage. You can find them at appliance or hardware stores. Plug the freezer back in to test operation of the bulb.
  • Have a nice day! : ))
    Jan 30, 2011 | Kenmore Refrigerators
    How to change the light in the refrig. compartment?
    Some models are different...I hope this helps.
    Replacing Light Bulbs
    To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
    To avoid personal injury or property damage, observe the following:
    • Allow light bulb to cool.
    • Wear gloves when replacing light bulb.
    Fresh Food Section
    (style of light shield varies)
    1. Slide clear light shield toward back of compartment to release from light assembly.
    2. Remove light bulbs.
    3. Replace with appliance bulbs no greater than 40 watts.
    4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
    Freezer (style of light shield varies)
    1. Reach behind the light cover.
    2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
    3. Remove the cover.
    4. Remove light bulb
    5. Replace bulb with appliance bulb no greater than 40 watts.
    6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
    Ric
    Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
    No light in refer but works in freezer
    Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
    John
    Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
    Refrigerators Logo
    97 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Marvin
    Marvin
