Question about Clarity Computers & Internet
Clarity display reads "screening" when you call it it is just busy. Cannot delete or remove
Posted by Sandra Venezia Allen on
Larry Ng
  • Clarity Master
  • 6,018 Answers
Where is the HS LOC button on the Clarity E814CC base phone
The Clarity E814CC doesn't have a Handset LOC button; it uses the Paging feature to contact the handset. To locate all of the handsets, press the Page/Flash button on the base with the phone system in idle (no calls in progress). The Page/Flash button is to the left of the Answering System On/Off button on the right side of the base. The button is almost aligned with the 1, 2, 3 number keys.
After you press the Page/Flash button, all of the handsets will sound the Paging tone and their screens will read "Paging". Press Talk/Speaker Phone on a handset or Page/Flash on the base, to cancel the Paging.
The Find the Handset information is in the manual on page 18. The location of the Page/Flash button is shown on page 8. The manual is available from Clarity Products here: http://shop.clarityproducts.com/products/clarity/e814cc/?cat=clarity . Click on the Owner Support tab. The direct link to the manual is http://shop.clarityproducts.com/media/ext/products/assets/E814CC_UserGuideEnglish_RevA.pdf .
I hope this helps.
Jan 10, 2018 | Clarity Lands Phones
Tip
How to clean an LCD TV
<span>An LCD screens must be cleaned as it attracts dust like a magnet. Cleaning is risky as the screens are very sensitive and there are chances of you damaging the screen if you don't know the proper method to clean it. To help you in this read the article below to the various tips on cleaning the LCD TV.</span> <b>Tips On Cleaning LCD TV</b> <b>Basic Facts About LCDs</b> <ul> <li>LCD screens or displays should not be cleaned through normal methods, as they are not glass. LCD or liquid crystal display is a soft film and it can be damaged through improper cleaning agents.</li> <li>The popularity of LCD TV's is on a rise as they can be can be run on low battery power and also have<a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>sharp</span></a> picture clarity.</li></ul> <b>LCD Screens Problems</b> <ul> <li>LCD screens regularly gather dust and smudges and sometimes fingerprints and ink markings.</li> <li>Cleaning the screens with a <a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>paper</span></a> towel, dishcloth or tap water can do considerable damage, as the screens are very sensitive. It can cause clouding and can cause damage to the pixels.</li> <li>Tap water contains chemicals like chloride and wiping the screens with it can leave a residue on the screen.</li></ul> <b>Cleaning Tips And Guidelines</b> <ul> <li>The LCD TV must be cleaned regularly for you to enjoy the proper clarity of the display.</li> <li>First of all, turn off the LCD TV and examine the condition of the screen.</li> <li>Note the smudges and the areas to be cleaned.</li> <li>To remove dusts use a microfiber cloth and brush off the dust particles.</li> <li>It is best to use proper cleaning solutions that come with LCD cleaning kits. However, you can mix one part of isopropyl alcohol with one part of distilled water and using cotton or microfiber cloth, clean the screen. Another cleaning solution that can be made at home to clean LCD TV's is to mix one part of vinegar in one part of water. Pour this solution on a soft cloth and then wipe the screen.</li> <li>Take care not to spray any sort of cleaning solutions directly onto the screen. Instead take it on a piece of cloth and then wipe.</li> <li>Wipe the screen in a circular motion and be very gentle. Don't press hard.</li> <li>Also do not touch the screen with your fingers or there are chances of leaving oily prints.</li> <li>Rub a soft cotton dry cloth to completely remove excess liquid from the screen as the moisture may damage it.</li> <li>Before switching back the TV on, let the screen dry completely.</li> <li>If some stains or marks are hard to remove, don't apply pressure to remove it. Instead, repeat the cleaning procedure several times to get rid of it. For ink marks and other hard stains, you have to invest in special cleaners.</li> <li>To clean the dirt from the edges or corners use a Q-tip. Dip one end of the Q-tip in the cleaning solution and squeeze out the excess moisture from the cotton tip. Now gently drag this tip along the edges.</li> <li>Do not use cleaning solutions that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the LCD screen materials and damage it.</li></ul>
on Jan 18, 2011 | Televison & Video
How do I delete a book from my device that I have finished reading?
To remove a book or magazine from your Kindle Fire HD libraries, follow these steps:
  1. On the Home screen, tap Books or Newsstand to display your library.
  2. Locate and press your finger on the item you want to remove. A menu appears.
  3. Tap Remove from Device press the helpful button
How to delete books from Kindle Fire HD
How to Delete from Kindle Fire
How to Delete Books and Docs From Kindle Fire HD8 HD10
Feb 04, 2016 | Amazon Kindle Fire HD 8.9"
On my cobra 29 lx camo i can read the lcd screen only from the very side of the unit, not straight on. what does that mean? every thing is lit up so bright u cant see anything head on.
I'm not an expert in electronic devices so this is only tentative advice. I've experienced similar problems with a couple of LCD digital clock displays and I found that looseness in the LCD panel mounting installation caused fluctuation of the clarity of display. Some added packing with shims of paper or cardboard strips to keep the layers of the LCD panel more firmly compressed together restored the display clarity. You will have to open up the device and go inside it to check this out. Observe electrical safety routines in the process. Other option is try replacing the LCD panel with a new one if possible.
Jan 08, 2015 | Cobra Radio Communications
How do i delete numbers from my BT XENON 1500 phone
Delete an entry in the phonebook
1. Press Names.
2. Scroll to the entry you want.
3. Press Options and scroll to Delete Entry and press OK.
Display shows Delete?
Press Yes to confirm or No to cancel.
4. Press Back to return to the standby screen.
Jul 13, 2014 | Computers & Internet
How do i delete buttons from the menu screen
Hi joywill426,
Go to your OPTIONS screen, choose SETUP, then TOUCH SCREEN CONFIGURATION. Click on the ITEMS & DEPARTMENTS tab. On nthe left, highlight the department that you wish to delete items (buttons) from. On the right, highlight actual item to be deleted. Under list box, uncheck box for DISPLAY ITEM ON TOUCH SCREEN. You can then move item to the bottom of the list with the DOWN button. Click SAVE & EXIT. FYI: This does not delete item from inventory, just removes it from the display screen. You will need to cycle out and back in to department to see the change.
B Mattern
[email protected]
Please return and give me a favorable rating if this helps or is of value to you.
May 11, 2011 | Pc America Restaurant Pro Express
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can...
IT IS NOT HARDWARE PROBLEM
Change screen resolution
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Nov 13, 2010 | Intel D945GCCR Motherboard
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Computers & Internet Logo
Top Clarity Computers & Internet Experts
k24674
Are you a Clarity Computer and Internet Expert? Answer questions, earn points and help others
