Question about Refrigerators
PG&E shut off electricity numerous times. Sub Zero will not come back on.
Posted by Barb Colutier on
Tom Chichester
    Top Expert:
  • Refrigerators Master
  • 61,812 Answers
Possibly your Sub Zero refrigerator has an internal circuit breaker which got popped one too many times and finally failed to reset.
Posted on Oct 29, 2020
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../condenser-fan-motor-operation
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ...
homeguides.sfgate.com > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
2answers
How do i shut off and reset sub=zero 690 fridge?
Its not necessary when "Vacuum Condenser" light is blinking means That condenser is dirty. That light will come on if compressor running too long. Most common problem is that Evaporator coil in fresh food section is leaking freon. It still might keep temps ok, but compressor need to run much more to keep temperature you set. check back wall in fresh food section on left side at the middle, behind drawers. if you see moisture in one spot or a little bit of ice build up, then You will need to call people who can replace evaporator. It is pretty expensive fix. I made video how it looks to repair this problem. Thanks.
Electricity went out and my sub zero will not stop beeping
I would turn off unit by the control, then turn back on to reset computer, if this does not work or reset get back to me and we can do a force start.
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Control panel is reading EC but numerical code...temperature reading is erratic as well. I turned the unit off and waited for 5 minutes and then turned it back on. I don't hear the unit running and EC is...
This is you electronic control board that is going out. You should probably repalce it as soon as possibel to prevent further parts from going out on your Sub Zero.
We are Sub Zero Parts Suppliers and will be happy to get this board out to you asap if you will contact us.
We hope this solves your problem and we look forward to being able to assist you with other appliance issues.
Freezer always on
The service technician was partially correct. The compressor does not run all the time, but the fan inside does, and this actually is for efficiency. There must be something else affecting your electric bill.
Sub-Zero 601R Electrical
have you checked the main power button on top of the unit, behind the grill?
10helpful
Sub-Zero 680 - Service light flashing/need to change the filter
The service flashing means that you had a long run time over a period of time. You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that will clear the fault code. If it comes back you have a problem that needs to be addressed such as cleaining the condensor. There is no factory filter on these units. If there is a filter it is most likely under the unit, which can be accessed by removing the kick. THe kick plate is held in place by two phillips head screws, remove them and have a look. If it was done by a "professional" they should have put an inline shut off valve for easy replacement of the filter.
Condensation and water in refrigerator
It sounds like you need someone who knows what they are doing out to your house. A tech should find and repair or replace the component that leaks. A second trip should be not be needed. The fact you have mold tells me they have never properly did your repair. Mold will grow only when the cavity gets above 40 degrees for a sustained period of time. use http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 or call 800-222-7820 and explain the situation and get another company to fix it right.
Sub Zero Frezzer drawer
I had the same problem. I found the piece of plastic in the ice tray and couldn't figure how to put it back. I ordered a new ice flapper from the parts place on the internet and installed it. The ice maker now shuts off. Good Luck.
Rick S.
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
